Osiron2's avatar
Osiron2
5 hours ago
VM intercepting my incoming calls
I  have always used my own cordless Gigaset answering machine if I can't reach a phone within the set delay period of 30 sec, however having switched from Talktalk to VM broadband and Weekend chatter, if I'm out, although I receive an indication on the answering machine that someone called me the messages left are replaced by 2 bursts of ringing tone. I have never asked for VM voicemail nor do I want it, nor is it specified. I suspect that VM is intercepting my incoming calls with their voicemail. Please can this either be disabled or made much longer than 30 seconds. Thanks.
  • Sorry, all I'm given is a greeting to set it up and 3 options to use my own greeting, to use a standard VM one... and Star to exit the tutorial. No option to change delay or to disable.
    I think this needs a moderator that has back end access to VM's system
    • Martin_N's avatar
      Martin_N
      Right I see. It is unusual that isn't working for you.
      We can certainly look into this for you.
      I will private message you now.
      ^Martin
  • Hi Osiron2,
    Thank you for your post. We're sorry to hear about your calls.
    As Graham_A has advised you can disable your voicemail via that process.
    ^Martin
  • Graham_A's avatar
    Graham_A
    You should be able to turn voicemail off by dialling 1571 and following the instructions.
    See: https://www.virginmedia.com/help/landline/set-up-landline-voicemail
