LouiseCrawford's avatar
LouiseCrawford
Just joined
19 hours ago
Replacement External Phone Wall Cover
I keep trying to report that the external wall cover is literally handing off my wall but every time I rung customer services I can’t get through to the right area to report it
does anyone know which options I have to press to get through to a person, so that I can report it please?
Every option I’ve tried just sends me links to “how tos” and then hangs up.
many thanks
I have seen some else post the same issue before and the advice given by one user was to wait in here and Virgin will send a private message, which they did so i am copying this communication method.
Thank you
1 Reply
  • Hello LouiseCrawford.
    Thanks for your first post and welcome to our community.
    Sorry to hear you are having an issue trying to arrange a replacement cover.
    I'd like to investigate this for you and book an engineer to pop round to do this.
    If you don't mind, I'll need to send you a private message to pass security.
    If you can check your logo at the top right of your screen that would be great.
    Gareth_L
