fsxtc's avatar
fsxtc
11 months ago
Another answer phone problem
Problem has been occurring for the last 5 or 6 weeks.
It appears that when I have several messages I go to listen to them and part way through the playback the line goes quite - it does not disconnect me from the line, just the message goes silent.  You cannot delete it at this time, all you can do is hang up and dial the 1571 again to connect and then delete the message as usual.  This then moves on to the next message which sometimes does exactly the same or sometimes doesn't?? - there is no rhyme or reason as to when it will do it, only that the problem will occur at some stage during listening to my messages.
I sometimes have to call back 5 or 6 times just to listen and delete my messages - help required please.
  • Hi fsxtc,
    Thank you for your post and welcome to the community.
    We're very sorry to hear about the issue with your landline service.
    Have you been able to try a new handset on the line?
    ^Martin
  • fsxtc's avatar
    fsxtc
    Hi Martin - 'yes' I have tried another and it is just the same.  If I could reset the service I would do as that could help? - but there is no reset that I can hear.
    • Robert_P's avatar
      Robert_P
      Thanks for confirming that, so we can take a closer look I will send you a Private Message, please keep an eye out in the top right when signed into the forums for the envelope. This is where you will be able to find my Private Message and be able to respond.
