Applescruff's avatar
Applescruff
3 months ago
Upgrade to volt 500mbps
On Monday I upgraded to volt 500mbps, the speed has dropped like a stone, when I was on volt 300mbps I was getting 330mbps plus on my mobile speed test, now I'm getting 11.2mbps What's going on? I have unplugged rebooted etc, still the same.
  • Roger_Gooner's avatar
    Roger_Gooner
    Log into the hub's Network status and you should see the following:
    On downstream: Max Traffic Rate 575000085 bps
    On upstream: Max Traffic Rate        55000085 bps
    If you have much lower figures there is a provisioning failure, so call VM, explain the problem and say that the hub has the wrong speed profile and to reprovision the modem and push out the correct config file*. Don't allow them to lazily book a tech.
    I'm also on M500, my config filename is cmreg-vmdg660-bbt053+voc-b.cm, and yours should be similar. Note bbt053 which indicates the M500 tier.
    • Applescruff's avatar
      Applescruff
      It reads the same as yours
      and config file is similar to what you have stated.
    Roger_Gooner
    There's another three reasons for the problem. Post your downstream and upstream stats by copy and paste.
    • legacy1's avatar
      Isn't all this talk about real speed to the hub meant to show if fine means the hub Docsis is fine?
      The problem is the bad wifi on the hub.
    Using the Realspeed test click on Run full test and re-post the results.
    Lets see if the Upstream is also slow on the mobile phone.
    To see a Wi-Fi speed in the 330Mbps range the 5GHz band is going to be needed.
    In the Hub's Connected Devices menu, is the mobile phone shown as connected
    to the Hub's Wi-Fi via the 2.4GHz band or via the 5GHz band ?
    Applescruff
    Sorted it out 5ghz manual channel instead of auto, turned off channel optimization and set channel width to 20/40/80 MHz.
    Thanks for all help and suggestions appreciated.
    • Deepak_S's avatar
      Deepak_S
      Hi Applescruff,
      Do you require anymore assistance or has the community got it all sorted😅
      Please let us know, thanks!
    • Steven_L's avatar
      Steven_L
      Thanks for coming back to us, Applescruff and we're glad that you've been able to get your issues resolved. Additionally, if you have any issues or questions now or in the future, please don't hesitate to let us know here, and we'll be happy to assist you.
      Kind Regards,
      Steven_L
