steve-o's avatar
steve-o
1 month ago
T3 timeouts & dropping connections
As title. Hub 5, in modem mode.
Physical connections checked then rebooted at 19:24 this evening to see whether timeouts issues persist - looks like yes. I think the timeouts explain the dropped connections. It's been like this for a couple of weeks now.
There were lots of downstream post-RS errors prior to reboot, but it's not been rebooted for a while.
3.0 Upstream channels
0 49600000 48.5 5120 QAM 64 1
1 43100000 48.5 5120 QAM 64 2
2 36600000 48.5 5120 QAM 64 3
3 30100000 48.5 5120 QAM 64 4
4 23600000 48.8 5120 QAM 64 9
0 ATDMA 0 0 0 0
1 ATDMA 0 0 0 0
2 ATDMA 0 0 9 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
3.1 Upstream channels
10 10.4 43.7 2K QAM 256
10 OFDMA 208 74000000 0 0
3.0 Downstream channels
1 139000000 6.2 39 QAM 256 1
2 147000000 6.6 39 QAM 256 2
3 155000000 6.6 39 QAM 256 3
4 163000000 6.8 40 QAM 256 4
5 171000000 6.9 40 QAM 256 5
6 179000000 7.1 40 QAM 256 6
7 187000000 7.2 40 QAM 256 7
8 195000000 7.8 41 QAM 256 8
9 203000000 8 41 QAM 256 9
10 211000000 8.1 41 QAM 256 10
11 219000000 8 41 QAM 256 11
12 227000000 8 41 QAM 256 12
13 235000000 8 41 QAM 256 13
14 243000000 8 41 QAM 256 14
15 251000000 7.7 41 QAM 256 15
16 259000000 7.5 40 QAM 256 16
17 267000000 7.5 40 QAM 256 17
18 275000000 7.8 41 QAM 256 18
19 283000000 8.9 41 QAM 256 19
20 291000000 9.8 41 QAM 256 20
21 299000000 10 41 QAM 256 21
22 307000000 10.2 41 QAM 256 22
23 315000000 10.3 41 QAM 256 23
24 323000000 10.4 41 QAM 256 24
25 331000000 10.3 41 QAM 256 25
26 411000000 9.9 41 QAM 256 35
27 419000000 9.7 41 QAM 256 36
28 427000000 9.8 41 QAM 256 37
29 435000000 10.3 41 QAM 256 38
30 443000000 10.7 41 QAM 256 39
31 451000000 10.9 41 QAM 256 40
1 Locked 39 0 0
2 Locked 39 0 0
3 Locked 39 0 0
4 Locked 40 0 0
5 Locked 40 0 0
6 Locked 40 0 0
7 Locked 40 0 0
8 Locked 41 0 0
9 Locked 41 0 0
10 Locked 41 0 0
11 Locked 41 0 0
12 Locked 41 0 0
13 Locked 41 0 0
14 Locked 41 0 0
15 Locked 41 1 0
16 Locked 40 0 0
17 Locked 40 0 0
18 Locked 41 0 0
19 Locked 41 0 0
20 Locked 41 0 0
21 Locked 41 0 0
22 Locked 41 0 0
23 Locked 41 0 0
24 Locked 41 0 0
25 Locked 41 0 0
26 Locked 41 0 0
27 Locked 41 0 0
28 Locked 41 0 0
29 Locked 41 0 0
30 Locked 41 0 0
31 Locked 41 0 0
3.1 Downstream channels
41 94 4K 1840 QAM 4096 1108
41 Locked 0 10.5 268124901 0
22-01-2026 21:23:37 critical No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 21:23:35 critical Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 21:23:35 critical 16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 21:23:29 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 21:10:35 notice US profile assignment change. US Chan ID: 10; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 21:05:32 notice US profile assignment change. US Chan ID: 10; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 20:53:24 notice US profile assignment change. US Chan ID: 10; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 20:48:21 notice US profile assignment change. US Chan ID: 10; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 19:24:30 notice REGISTRATION COMPLETE - Waiting for Operational status
22-01-2026 19:24:20 notice DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 19:24:17 notice TLV-11 - unrecognized OID;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 19:24:14 warning DHCP WARNING - Non-critical field invalid in response ;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 19:24:12 notice Honoring MDD; IP provisioning mode = IPv4
22-01-2026 19:24:01 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 19:23:59 critical Cable Modem Reboot because of - Reboot UI
22-01-2026 19:15:56 critical No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 19:15:46 critical No UCDs Received - Timeout;;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 19:15:30 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 13:52:18 critical No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 13:52:18 critical No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 13:51:44 critical No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 13:51:42 critical Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 13:51:42 critical 16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 12:56:28 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 01:11:30 critical No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 01:11:29 critical Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
22-01-2026 01:11:29 critical 16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
21-01-2026 15:49:14 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
20-01-2026 23:10:50 critical No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
20-01-2026 23:10:48 critical Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
20-01-2026 23:10:48 critical 16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
20-01-2026 23:10:42 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
  • Hi steve-o 👋
    We're sorry to hear you've been experiencing problems with your hub in modem mode. Thank you for flagging this to us. We are hoping to book you a technician visit to assess the issue further. Please look for our PM 🙂
  • Tudor's avatar
    Stats are very good, only 1 upstream channel with some T3 errors, but some of the downstream channels power levels are too high. If you get obvious faults, not just some T3 errors and log messages then follow this.
    Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web service status page, but this is not recommended as it only covers issues that affect a very large number of customers.
    VM will not dispatch any technicians while an area fault exists.
    If no area faults found:
    The primary place to report faults or for service requests is Customer Services on 0345 454 1111/150 if you have a VM landline or wait two or three days for a VM staff member to get to your post. This board is not a fault reporting system nor a direct line to VM.
