mark1stewart's avatar
mark1stewart
Latency slower than when i was on copper broadband
when i was on copper previously with a different comapnay i was getting latency of around 10-15ish.
this fibre keeps above 30ms and jumps around to 60-70-80 sometimes.
been looking at the router pages and seen what ive pasted below.
a few pre-rs-errors on different channels, but the bottom number, the Corrected Errors seems really high.
Could this be causing the latency, or is it just gonna be like this.
3.0 Downstream channels
1Locked4130
2Locked4310
3Locked4310
4Locked4320
5Locked4340
6Locked4360
7Locked4300
8Locked4310
9Locked4300
10Locked4310
11Locked4300
12Locked4310
13Locked4330
14Locked4310
15Locked4300
16Locked4320
17Locked4210
18Locked4230
19Locked4200
20Locked4200
21Locked4220
22Locked4130
23Locked4150
24Locked4120
25Locked4110
26Locked4120
27Locked4220
28Locked4200
29Locked4230
30Locked4220
31Locked4200
32Locked4200
3.1 Downstream channels
159944K1840QAM 40961108
159Locked421.827305482310
  • oh and looking that corrected errors column is going up quite quickly..
    159Locked421.927410042600
  • Just putting the rest of the downstream data here:
    13310000004.441QAM 25625
    21390000005.443QAM 2561
    31470000005.443QAM 2562
    41550000005.343QAM 2563
    51630000005.343QAM 2564
    61710000005.243QAM 2565
    71790000005.243QAM 2566
    81870000005.243QAM 2567
    91950000005.443QAM 2568
    102030000005.343QAM 2569
    112110000005.643QAM 25610
    122190000005.543QAM 25611
    132270000005.543QAM 25612
    142350000005.343QAM 25613
    152430000005.343QAM 25614
    16251000000542QAM 25615
    172590000004.942QAM 25616
    182670000004.842QAM 25617
    192750000004.842QAM 25618
    202830000004.842QAM 25619
    212910000004.942QAM 25620
    222990000004.941QAM 25621
    233070000004.841QAM 25622
    243150000004.741QAM 25623
    253230000004.541QAM 25624
    263390000004.341QAM 25626
    273470000004.442QAM 25627
    283550000004.242QAM 25628
    293630000004.342QAM 25629
    303710000004.142QAM 25630
    313790000004.242QAM 25631
    323870000004.142QAM 25632
    • Ashleigh_C's avatar
      Ashleigh_C
      Hi there mark1stewart
      Thank you so much for your post and welcome back to the forums, it's great to have you here.
      I am so sorry that you have faced this issue with your service and thank you to our community teams for their help so far.
      I have taken a look on our side and I cannot see any issues that could be causing this, can I ask how things have been looking since your last post?
  • Corrected errors on that channel expected and normal. If you chose VM and hoped for lower latency you're in for disappointment, what you're getting is the normal cable experience.
  • On the 3.0 channels corrected errors can indicate the network is marginal, large quantities are expected on the 3.1 channel, it uses a different error correction scheme that has a lot more coding gain and pushes the network much harder.
    • Anonymous's avatar
      Anonymous
      Approved
      To add: 100% of the codewords can be corrected on the OFDM channel and everything is fine. The counter doesn't reveal how hard it has to work to correct the errors, so it must be excluded when troubleshooting. The log will tell, if it needs to work too hard, which results in a change of modulation (event codes 16/24).
    Please share a screen shot of the latency figures :
    The link below shows latency to the Hub and latency to your device :
    Once the test begins click on: Run full test to include: Latency, Jitter, Packet loss & Upload speed
