Imosgoal's avatar
Imosgoal
Intermittent connection nonstop
Hi all, after searching threads it seems others have had this issue but Virgin take them to a private chat to solve the issue.
devices: 2 laptops on Wi-Fi, 1 laptop on Ethernet, 2 mobiles.
Issue: every 30 minutes internet drops on all devices and takes 5 mins to reconnect. In this time hub stays solid white.
    Try checking with Area faults on  0800 561 0061 or if you have a VM landline 150 as small local faults are not listed on the VM status page.
    Post the power levels, Pre and PostRS errors and network log from the Hub.  Once done we can comment
    • Imosgoal's avatar
      Imosgoal
      Advises no faults in the been checking this for 2 weeks, I can only assume it’s the cabinet, router or VM throttling my speeds.
      they’ve changed everything in the last 3 weeks, new router made it worse.
  • Tudor's avatar
    Here is how to post requested data so it can be read:
    How to get stats from a VM hub (no need to logon to the hub)
    Open a web browser and go to 192.168.0.1 router mode or 192.168.100.1 modem mode
    • Click on the “> Check router status” button
    • Click on the “Downstream” tab, copy the text and paste into your reply, do not take a screen shot
    • Click on the “Upstream” tab, copy the text and paste into your reply
    • Click on the “Networking” tab, copy the text and paste into your reply.
      • Do NOT post photos or screen shots they will be rejected as they contain MAC addresses. The board software will automatically change MAC addresses to **:** if done as above.
  • 3.0 Upstream channels
    Channel	Frequency (Hz)	Power (dBmV)	Symbol Rate (ksps)	Modulation	Channel ID
    0	49600000	45	5120	QAM 64	1
    1	43100000	44.8	5120	QAM 64	2
    2	36600000	44.3	5120	QAM 64	3
    3	30100000	44.3	5120	QAM 64	4
    4	23600000	44.3	5120	QAM 64	5
    Channel	Channel Type	T1 Timeouts	T2 Timeouts	T3 Timeouts	T4 Timeouts
    0	ATDMA	0	79	0	0
    1	ATDMA	0	79	0	0
    2	ATDMA	0	79	0	0
    3	ATDMA	0	79	0	0
    4	ATDMA	0	79	0	0
    3.1 Upstream channels
    Channel	Channel Width (MHz)	Power (dBmV)	FFT Type	Modulation
    6	10.4	40.2	2K	QAM 256
    Channel	Channel Type	Number of Active Subcarriers	First Active Subcarrier (Hz)	T3 Timeouts	T4 Timeouts
    6	OFDMA	208	74000000	0	0
    3 engineers, next out on Saturday, this one ain’t leaving till it’s resolved or VM cancel the contract so I can go to BT.
  • All the previous threads lead to a damaged cable between house and cabinet, seen as I have brand new cable from route to the street, only that remaining.
    • IPFreely's avatar
      IPFreely
      Rising star
      Agreed. Downstream is broken, see the T2 timeouts?
  • 3.0 Downstream channels
    Channel	Frequency (Hz)	Power (dBmV)	SNR (dB)	Modulation	Channel ID
    1	163000000	8.4	43	QAM 256	4
    2	155000000	8.5	43	QAM 256	3
    3	171000000	8.4	44	QAM 256	5
    4	179000000	8.4	44	QAM 256	6
    5	187000000	8.4	44	QAM 256	7
    6	195000000	8.4	43	QAM 256	8
    7	203000000	8.2	43	QAM 256	9
    8	211000000	8.4	44	QAM 256	10
    9	219000000	8.2	43	QAM 256	11
    10	227000000	8.1	43	QAM 256	12
    11	235000000	7.9	43	QAM 256	13
    12	243000000	7.6	43	QAM 256	14
    13	251000000	7.3	43	QAM 256	15
    14	259000000	7.3	43	QAM 256	16
    15	267000000	7.3	43	QAM 256	17
    16	275000000	7.2	43	QAM 256	18
    17	283000000	7.1	43	QAM 256	19
    18	291000000	7.1	43	QAM 256	20
    19	299000000	6.9	43	QAM 256	21
    20	307000000	6.8	43	QAM 256	22
    21	315000000	6.6	43	QAM 256	23
    22	323000000	6.5	43	QAM 256	24
    23	331000000	6.4	43	QAM 256	25
    24	339000000	6.3	43	QAM 256	26
    25	347000000	6.1	43	QAM 256	27
    26	355000000	5.9	43	QAM 256	28
    27	363000000	5.9	43	QAM 256	29
    28	371000000	5.7	43	QAM 256	30
    29	379000000	5.7	43	QAM 256	31
    30	387000000	5.6	43	QAM 256	32
    31	395000000	5.5	43	QAM 256	33
    Channel	Locked Status	RxMER (dB)	Pre RS Errors	Post RS Errors
    1	Locked	43	4253	5945
    2	Locked	43	5819	9793
    3	Locked	44	9558	16967
    4	Locked	44	9997	17137
    5	Locked	44	6200	10661
    6	Locked	43	9074	14866
    7	Locked	43	9778	15189
    8	Locked	44	7838	12295
    9	Locked	43	8826	14862
    10	Locked	43	7039	12294
    11	Locked	43	3445	5301
    12	Locked	43	4429	7790
    13	Locked	43	4560	8090
    14	Locked	43	5443	10297
    15	Locked	43	4638	7983
    16	Locked	43	4390	7558
    17	Locked	43	7652	12333
    18	Locked	43	4290	8612
    19	Locked	43	4703	8599
    20	Locked	43	3894	7164
    21	Locked	43	4061	7321
    22	Locked	43	3765	6521
    23	Locked	43	5312	9686
    24	Locked	43	1741	4617
    25	Locked	43	2486	4364
    26	Locked	43	3780	6301
    27	Locked	43	3606	5672
    28	Locked	43	3864	7315
    29	Locked	43	3632	7184
    30	Locked	43	3817	6608
    31	Locked	43	2851	6016
    3.1 Downstream channels
    Channel	Channel Width (MHz)	FFT Type	Number of Active Subcarriers	Modulation (Active Profile)	First Active Subcarrier (Hz)
    37	94	4K	1840	QAM 4096	1108
    Channel ID	Locked Status	RxMER Data (dB)	PLC Power (dBmV)	Corrected errors (Active Profile)	Uncorrectable errors (Active Profile)
    37	Locked	41	-0.9	963253450	17547
  • So how do I go about reporting VM as they can’t provide a contractual service?
    Do keep the engineer here till they’ve dug the street up and laid a new cable to the cabinet? At this point I’ll pay BT prices to have a decent service.
    • Daniel_Et's avatar
      Daniel_Et
      Hi Imosgoal 👋 Thank you for your posts and welcome to the Virgin Media Community 😀
      We're sorry to hear about the issue you've been having with your internet connection and that you're thinking of leaving us 😔
      Please let us know how tomorrow's engineer visit goes and we can take things from there.
      Thank you for your support Adduxi, Tudor and IPFreely 👍
      Regards,
      Daniel
      • Imosgoal's avatar
        Imosgoal
        He couldn't resolve the issue, advised its possibly a network problem but unless, he is there when it happens VM can do nothing.
        He gave me his number so I have been sending him pictures of the failed upstream timeouts hoping he can log on when it happens to report it.
        Today 282 timeouts T2 _ 72 timeouts T3.
        Honestly I just want to leave VM asap, I can't even search the internet during the day without it disconnecting utterly useless paid service.
        0	49600000	44.8	5120	QAM 64	1
        1	43100000	41	5120	QAM 64	2
        2	36600000	45.5	5120	QAM 64	3
        3	30100000	40.8	5120	QAM 64	4
        4	23600000	45.3	5120	QAM 64	5
        0	ATDMA	0	282	72	0
        1	ATDMA	0	282	72	0
        2	ATDMA	0	282	72	0
        3	ATDMA	0	282	72	0
        4	ATDMA	0	282	72	0
