DeborahForum's avatar
DeborahForum
Dialled in
5 months ago
1Gb volt but WiFi a lot less?
Hi, we have just upgraded from 250mb speed to 1Gb - the WiFi speeds are now slower than on the previous 250mb package?
ethernet it full speed, just WiFi is slower, we are using the same Hub 5 router, nothing has change in the home.
we have had a few results of around 300mbs on WiFi speedtest, but usually around 150 mbps?
I was expecting WiFi speeds of somewhere near the 600mbs and upwards.
thanks
  • Hi,
    A gentle reminder to please keep replies polite, respectful and relevant, some posts have been removed
    Community Moderators
      Looking at those scans, your 5Ghz signal is very poor, it should be over -65dBm for a decent signal.  As for the 2.4Ghz, that's a congested area so not much you can do about that either.  However the plus point is the signal is stronger at -70 dBm, but still not great. Is also not helped by someone using Channel 8!
      Is the Hub in an open area with no interference about it?  Those signal levels are not good really.
      In comparison, I have 3 Wifi access points (Pods in VM speak) and the closest one to me at the moment is -36dBm and the one that is furthest away is -80dBm.
      I don't believe the speed tier would affect the performance of the Wifi antenna's in the Hub, and this just looks like interference or a bad placement.
      • DeborahForum's avatar
        DeborahForum
        Dialled in
        Hi, the hub has been in the same spot for over 3 years, before Virgin upgraded our WiFI speeds were perfect everywhere in the home, I could use it outside very well too. Since the upgrade the hub has been changed to another hub 5 to try and fix this issue a couple of weeks ago along with the cable upgrade to fibre to the property. One of the engineers did say he’d worked on the power to try and fix it, without success.
        I keep going back to the fact that everything was perfect until literally the moment Virgin upgraded the speed.
        We’re now frustrated as the last (3rd) engineer told me he’d call us in 2 days to arrange a more in depth appointment as he said it needed to be looked into in a lot more detail, but he did not call and we’ve just been basically dumped. Which is just not good enough.
        Hence, we are just stuck with this until Virgin decide to help.
  • As far as I'm aware, the routers need to be configured for each household, that what I was told by an engineer so I don't think borrowing a router works work? Also, I don't know anyone with one.
    The real answer is for Virgin to come out and fix it
    • Matthew_ML's avatar
      Matthew_ML
      Hey DeborahForum, thank you for reaching out and we are so sorry to hear about your connection speeds.
      We can see you are currently in DM with my colleague.
  • If I buy a 2nd hand Vodafone router with 6e technology, can I use it after putting Virgins hub5 into modem mode? I’m getting no where trying to improve my WiFi speeds, I was given a pod but it hasn’t improved it enough.
    im hoping the answer is yes then I can use the extra 5Ghz strength and 6Ghz for the devices that are compatible.
    Has anyone any experience with this? Thanks
      I don’t know about that Router. Being for Vodafone it may be locked down and not configurable?  Anyway it may not help, I mean looking at your WiFi analysis you have, by my count, 12 other WiFi signals in your location.  This makes it difficult to get good performance as each WiFi unit has to share the space. I’ve always said a single Router is not always the best solution. It may be better to ditch the Pods and setup a good quality Mesh or Access Points?  However this is not a cheap solution. At least you can manually setup everything to try and avoid WiFi clashes etc.  Not what you want to hear really?
      • Tudor's avatar
        "12 other WiFi signals in your location." Just a note: in the last 24 hours I have seen 130 2.4Ghz signals in my area. I use Ubiquiti/Unifi Wireless Access Points and I have no problems with devices that must use the 2.4Ghz band. It’s ’horses for courses’, cheap equipment does not last, you buy another lot and another lot, but by this time you have paid more than buying good equipment to start with.
  • legacy1's avatar
    So your going to seek compensation for the problem?
  • And do what with it? Buy a pizza? No I’m not interested in compensation. I’m putting myself through this never ending tedious back and forth in the hope of the company that I pay good money to each month will fix their equipment to work the way it should.
