p3tzz's avatar
p3tzz
Virgin Media Hub Power Cable Query
Hi, is the black power cable which goes into the hub 3 the same wire that goes into Hub 5 or is it different? Thanks all
1 Reply
  • Hi p3tzz,
    When you have a new hub, there should be a power supply with it. We would always recommend using the unit that comes with the hub.
    Please let us know if you have any further questions 😊
