Jackal1's avatar
Jackal1
2 months ago
Junction cabinet in my hedge
Virgin Media applied to the local highways agency to replace a 85cm high cabinet on the highway outside my house in 2023. They actually put a replacement 1.2m high by 1.2m wide cabinet in my hedge, next to my drive. Earlier this year they dug up my hedge looking for cables under the cabinet and the hedge is now wrecked. I can’t replace it with a fence because the cabinet is in the way. I’ve tried complaining but four months later I’m just being fobbed off with excuses or promised callbacks which don’t materialise. I want to escalate the complaint but am not sure where to go. Is it Ofcom or the Communications Ombudsman?
  • goslow's avatar
    goslow
    Plenty of reasons CISAS is likely to not get involved in such a dispute described in
    https://www.cedr.com/wp-content/uploads/2025/12/CISAS-Scheme-Rules-Jan-2026.pdf
    The complainant needs to be/have been a VM customer or in the process of signing up (not sure if the OP is) and property damage is excluded under the scheme (amongst various other things listed which might lead to exclusion).
    OP needs some proper legal advice IMO. As per Roger_Gooner though, I suspect they are not going to get very far with changing the cabinet or its position.
  • Roger_Gooner's avatar
    Roger_Gooner
    In reality, councils are very unlikely to order the removal of a live cabinet, particularly a large one. What they usually enforce instead is proper reinstatement, compliance with clearances, and mitigation of any obstruction or damage. Full removal tends to be a last resort where there’s a safety issue or clear non-compliance.
    Even if a cabinet turns out to be on private land without a wayleave, councils usually won’t intervene as it’s a civil matter and removal of a live cabinet is still uncommon in practice. You can take VM to court to get an order for removal, but this is slow, expensive and unpredictable as courts usually see as disproportionate the removal of telecoms infrastructure serving the public interest. I believe goslow has a point about timing: while time doesn’t automatically make an unauthorised installation lawful, the longer a live telecoms cabinet has been in place, the less likely a court is to order its removal. As time passes, proportionality, third-party reliance and public interest increasingly favour regularisation or compensation rather than removal.
    Ofcom won’t handle individual complaints, so they won’t resolve this. The best route is to submit a formal complaint in writing (email or letter) and if, after eight weeks it isn’t resolved, request a deadlock letter which VM must issue. With that letter you can escalated to CISAS - which still is unlikely to order VM to remove the cabinet but can order compensation, force other remedial action and recommend that VM formalises access to the land by having both parties sign a wayleave.
    So, whether it's by escalatation to CISAS/Communications Ombudsman or court action these disputes usually end with a retrospective wayleave and/or compensation (hedge damage, inconvenience) rather than complete removal, unless there’s a clear safety or access issue.
  • If VM did not have wayleave to install this on your land, I would simply remove it myself , since you would be waiting forever and a day for VM to do anything about it. They are truly a waste of time and space. Present Board needs to step down, and go and find a job at a car wash or something.
    • Jackal1's avatar
      Jackal1
      There is no way leave. I am going to have to do something as I can’t fix the damage their contractors have done to my garden with it in the way.
      • goslow's avatar
        goslow
        Well, you seem to be tackling the issue at a fairly leisurely pace if the matter dates back as far as 2023. IMHO, the longer the problem drags on, the better VM's case for leaving things exactly as they are.
        Your last VM reply on here was a month ago with an offer to raise a complaint to the 'field construction complaints team'. What happened with that (I am guessing nothing whatsoever)?
        Reposting on here is unlikely to improve your situation as there is no mechanism on here to help fix your issue. The VM people on here can/will do nothing more than relay messages for you. Any comm's on here will, at best, just be sent into the abyss of VM internal communications, never to be seen again. As has been suggested on the topic earlier, you need to get proper legal advice to see what (if any) options you have.
        Edit: Crossed over with subsequent replies from the OP
  • legacy1's avatar
    https://www.youtube.com/watch?v=dSSqHhAqxrk&list=RDdSSqHhAqxrk&start_radio=1
      • nodrogd's avatar
        nodrogd
        I would have said this cab will likely be removed when VM moves to full fibre (the street FF distribution cabinet is the green one next to it). However, the 1.2 metre cabinets can also contain UPS backups for the local fibre networks, so there is no guarantee it will be removed in the future.
    Roger_Gooner
    You need to know where is the boundary line of your property - which may or may not defined by the hedge. And if it's the hedge: over time it may have grown significantly in width, so where is the centre - if the centre is actually the boundary?
    • Jackal1's avatar
      Jackal1
      I’ve checked the boundary line with the council. The cabinet is 40cm deep and at least 29cm is in my property.
        The Land Registry is where records of plots are held.
    Sharing some photographs of the situation would be very helpful.
  • goslow's avatar
    goslow
    What is it you are specifically complaining about? The fact that the cabinet is bigger or your hedge was damaged or both things?
      • jpeg1's avatar
        jpeg1
        Yoy will not got anywhere complaining to VM because they are not going to admit a mistake by their own contractors.
        This is a planning issue and you will need to take it up with the Council Planning department.  Copy your letter and photo to local Councillor/s and ask for their support.
    • Jackal1's avatar
      Jackal1
      The cabinet is higher than before so it should have had planning permission and it’s been put in my hedge and wrecked it but I can’t replace it with a fence as it’s across the boundary line.
      • Molly_T's avatar
        Molly_T
        Hi Jackal1 👋 Welcome to the community forum! Thanks for posting to bring this to our attention.
        Sorry to hear these concerns about a cabinet installation.
        What we'd need to do, is get a complaint raised for you. This will be assigned to the Field construction complaints team, who can liaise with yourself, the council and any other external parties needed to get the complaint resolved.
        I will send you a PM to confirm a few details, and get you to send over any evidence we may need to support your case. Please keep an eye on your Inbox 📩 in the top right corner of the page.
        We can return to this public thread with another update when possible. Thanks for your patience in the meantime! 🌞
  • Did you ever get this sorted?  Virgin applied to the highways department to put a Cabinet on the highway outside my house but they put it in my hedge instead. There was one before but it was 85cm high and the new one is 1.2m high, right next to my drive. To make matters worse, they have damaged the hedge  but I can’t replace it with a fence because the cabinet is in the way. I’m trying to get it moved but I just keep getting fobbed off with excuses and promises of phone calls that never materialise. Is there someone I can escalate this to? Ofcom? Communications Ombudsman?
