Tramca23's avatar
Tramca23
Constant red light light hub 3
I have a constant red power light on my hub 3. It tried the factory reset, as advised, but it never turns white, not even when turning it back on. It doesn't appear to be hot and is well ventilated, and at the moment my Internet/wifi is unaffected.
Is there another fix or does this need replacing?
Any advice welcome.
1 Reply
  • Hi Tramca23 thanks for posting and welcome back to our community.
    Thanks for reporting your red light on your hub and the steps you've taken to resolve it. Also sorry for any concerns you may have. I would like to take a look on your behalf. I am going to send you a private message. Please keep an eye on your inbox in the top right of your screen.
    Lee_R
