qholmes's avatar
qholmes
Just joined
19 hours ago
Cable won’t fit into wall
I have just received my hub 3 to set up my wifi. I can’t seem to get the cable to fit into the wall. I have taken photos of the cable and the coupling. I’m not sure whether I need to use more force, or whether the cables aren’t compatible. Any advice appreciated!
  • It’s just ‘push fit’ not screw on, although it does take a good push. Just make sure sure the centre pin is aligned.
  • Thank you! I’ve got it in now. I think I just needed some reassurance that it was definitely the right fit before I gave it a proper shove haha
  • legacy1's avatar
    Just jam it up there!  of course how well it stays on is another thought...
  • Tudor's avatar
