LB_2022's avatar
LB_2022
10 months ago
Power Supply Cable For Virgin Box
Hello,
I am unable to use my Virgin Box as one of my ‘little darlings’ has damaged the power cable, how do I go about ordering a new one please? I cannot find any information on the app.
Thank you in advance,
LB
    Is it the plug lead to PSU or the PSU cable to box that is damaged.
    You can either call Virgin on 150 from a Virgin phone, mobile or landline, or 0345 454 1111 from any other phone to report a fault, or wait here for one of the forum team to pick this up which might be 2 to 3 day's.
    When phoning choose the option to report a fault, then ignore all the options offered and you should then be placed into a queue to speak to someone.
    • LB_2022's avatar
      LB_2022
      I took your advice and called, selected 2 for faults, ignored the options then after third cycle of options it hung up on me! I didn’t get out through to a person! This system absolutely sucks!
      • Steven_L's avatar
        Steven_L
        Thanks for coming back to us LB_2022. Have you been able to speak to the team to get this arranged or do you still require further assistance?
        Kind Regards,
        Steven_L
  • Hi LB_2022, thank you for your query.
    I can see you've spoken to the team since you posted and that this has been sorted out for you.
    If you have any further queries, please don't hesitate to contact us.
    Thank you for your support roy247 👍
    Regards,
    Daniel
    • LB_2022's avatar
      LB_2022
      Good morning, this has not been sorted. So far I’ve received a coax cable (not required), an ethernet cable (not required) and today I’ve received a power supply cable… for my hub… not required! All I want is a black power supply cable for my virgin box!! Not the hub! How difficult is it?
        What exactly is the "Virgin box"?  That's not very descriptive really.  Is it a TiVo box, a V6 Box, a 360 Box, a 360 Mini, a Stream Box?  Some clarity would be needed to ensure the correct PSU cable is supplied.
