on 05-08-2024 20:08
Our box has started dropping the picture and sound when it’s woken up from the remote. The only way to stop it and be able to watch anything is to turn the box off at the mains and wait til it has booted up. We shouldn’t have to do this at all but recently we have been needing to do it several times a day. How do we report this and get a resolution?
on 07-08-2024 20:29
Hi @Any1else, thank you for your post.
We're sorry to hear about the problem you're having 😔
Just to confirm, after turning on the set top box via the remote control, is there a total loss of picture and sound or are they both going in and out intermittently?
Advice on how to fix TV box issues can be found here.
Regards,
Daniel
on 10-08-2024 07:14
Hello,
Check if there are any firmware updates available for your box. It's can improve performance also!
Hope that helps.
