- japittsVery Insightful Person
Can you explain your issue? Your post has been moved to a thread of its own, but all you've mentioned is "I'm the same".
- JOHN_G421Tuning in
We now have the red light on continually on the box, regardless the box is on or off. When we try to reset the box it takes forever (in excess of 8 mins) to boot up. The remote buttons are now very stiff, the ok button sometimes work but more often does not, the guide button is very hard to press down. Changed the batteries twice.
- Tom_W1
I've replied to japitts but heres what I wrote. We now have the red light on continually on the box, regardless the box is on or off. When we try to reset the box it takes forever (in excess of 8 mins) to boot up. The remote buttons are now very stiff, the ok button sometimes work but more often does not, the guide button is very hard to press down. Changed the batteries twice.
- Martin_N
Thank you for the update with that John_G421. We can certainly take a look into this.
I will private message you now to confirm your details.
^Martin
Related Content
- 11 months ago
- 7 months ago
- 2 years ago
