alancole's avatar
alancole
11 months ago
lights on 360 box not working
newly installed 360 box all info lights working,hour later when in standby red light went out,rang vm and was told i shall send info to box,after that all light stopped working and was told oh well i don't really know still you get all channels still and that was it conversation with vm ended,that evening phoned again to report it and was told not a problem you still get all channels,i then explained new installation was working but not now,i have 14 day cancellation option which if i don't get the service i shall use,sent message to 360 box all lights working,next morning after standby all lights not working ,i give up no help from vm
  • Hi alancole,
    If the light only goes off when the 360 is in standby it could be because the box is in Eco start mode, try setting it to fast start or active start if this is the case.
    On your 360 box go to Settings > System > Standby power consumption. You have 3 choices.
    Fast start - the 360 starts quickly but is less energy efficient
    Active start - more energy efficient than fast start but the box takes a little longer to start up
    Eco start - the most energy efficient it uses minimal power but takes a while to start.
    If you have no light when the box is in use I assume the first bit of advice was to turn the box off and then back on again with the switch on the back of the box or plug, if that hasn't worked then you could try a factory reset using the keep recordings option.
    To factory reset go to Settings > System > Factory Reset.
    It's only a partial system reset and not a complete factory reset. You are given 2 options,
    Keep Recordings
    Format Disk
    Choose Keep Recordings, that means you won't lose your recordings and any planned recordings or series links
    you've set up, you will have to sign into your apps such as iPlayer, Prime, Netflix and ITVX again, also Match
    frame rate and Standby power consumption will go back to their default settings if you have changed them.
  • Hi alancole,
    Keep Recordings
    Format Disk
    • alancole's avatar
      alancole
      thanks but there is no lights at all,the box is in fast start up,but no lights when its on or off
      • roy247's avatar
        roy247
        Superstar
        If the factory reset hasn't worked hopefully one of the forum team will pick this up but that might take 2 to 3 days. 🤞
  • That is normal.
    White is the 360 is on - Red is the 360 is in standby but doing something like a recording.
    No light and it has gone into a deep sleep until it is taken out of standby or starts a recording.
    • roy247's avatar
      roy247
      Superstar
      ozsat wrote:
      That is normal.
      You mean normal if set to Eco start.
      • ozsat's avatar
        ozsat
        Superstar
        Yes - which I think is the default.
        roy247 wrote:
        ozsat wrote:
        That is normal.
    • alancole's avatar
      alancole
  • All fixed now vm replaced the new box with another new box,all lights work so it turns out it was a faulty box
