on 04-12-2024 13:25
Hi, Virgin has emailed me to say we can have a free upgrade to 360. My wife is disabled and we use a BroadLink RM3 to change channels, and control the tv for her when I am not in. My question is does anyone know if the 360 remote will work with the BroadLink. The RM3 uses infrared.
Also do I have to update - currently have a V6 box with no issues.
thanks for any info.
on 05-12-2024 08:58
You do not have to upgrade (at this time) and I would look into the differences between the systems before deciding to as there are a lot of features missing compared to the V6\TiVo systems, a lot of the main features are also harder to navigate to (i.e. getting to recordings takes 7 presses instead of 1 I believe) which may not be ideal in your situation, it does have voice control but only if you use the supplied remote control and it requires a button to be pressed on the remote to activate it (which seems to defeat the point of it).
I think the 360 works with universal remotes, so I would assume it would work with the IR of the Broadlink.
