on 07-04-2024 15:03
surely when a program overruns it is possible to advise the viewers. Today it was at 13:30 World Challenge Europe motor racing was advertised and F1 overran previous 2 programmes, causing the guide to be out of date.
Answered! Go to Answer
on 07-04-2024 16:06
Did the EPG match the broadcaster's published schedule for these programmes? If so, it's operating as designed.
On Freeview & Freesat, I believe the broadcasters have direct access to the EPG to make amendments in close-to real-time.
This is not the case on VM, where EPG updates go through a third-party process, partly because of the additional data carried. In any case, it's always been this way - and live event overruns can never be legislated for.
I'm not familiar with the specifics of how TV360 operates, but TiVo/V6 certainly prompt you when recording live events, whether you want to add additional recording padding time afterwards.
on 07-04-2024 16:06
07-04-2024 18:41 - edited 07-04-2024 18:44
I always use the Advanced options when recording F1 and add 3 hours to the scheduled recording in case there's red flags and the race is extended, also this usually means I can watch the follow up F1 scheduled programmes without setting separate recordings.
If you are watching any live events and there is a chance it will overrun it's best to use the Advanced options and extend the recording time.
