3 weeks ago
A few days ago I received the new remote and I was than able to update the V6 box to a 360. All went smoothly and everything appears to work as expected.
Initially, the led on the front of the box displayed as described but after a short time the led turned off and has remained off everr since. This means that I have no idea as to the stye of the box
Is this a fault with the box or have I inadvertantly turn-off the led?
Answered! Go to Answer
3 weeks ago
There isn't a setting to turn the led off.
If the box is set to eco start try setting it to fast start or active start and then reboot the box, switch the box off with remote and then turn the power of for about 30 seconds before turning it back on and then switch it back on with the remote.
If the led still doesn't work then it would seem to be a faulty box.
3 weeks ago
2 weeks ago
One of the consquences of the leds not showing was that I had no idea whether the box was on, or not. Clicking the box on, when it is fully off, initially produces no immediate response so tou have no idea whther the box has racted to the key press.
At one point I held down the remote on-key for quite a few seconds to se if this would initiate a reset (desparate measures!)but no such luck. Sometime later I wondered if this long press had caused the leds to go off so I tried holding the on-button down for a similar time and the leds reappeared.
Now I cannot be sure that the reaapearance of the leds was due to the long pree as I did quite a few other things; perhaps I was just lucky.
Anyway, once again thnaks roy247
