on 20-01-2024 16:37
We like to watch some recordings in double time, and with our old HHD recorder were able to do this, With the TV 360 box, there is no sound when on fast forward. Might anyone know if it possible to do this, and if so, how? It's particularly handy when watching motorsport and often barely effects the commentary.
I have looked in settings but found nothing which would seem to enable this. We can't be the only ones who think some shows benefit from speeding up.
Answered! Go to Answer
on 20-01-2024 17:32
Hi Pebblesucker,
That feature was called Quickview and is one of the many features patented by Tivo so will probably never appear on the 360 which uses Global Media's in-house software Horizon.
on 20-01-2024 17:32
Hi Pebblesucker,
on 20-01-2024 18:44
TV360 runs different software to TiVo/V6 and is fundamentally different.
As mentioned above, you've found one of the many differences.
on 19-03-2024 16:00
I find this change so annoying. I watched most things on FF. Also I find the new guide much more time consuming compared to being able to look at each channel's full day in one go. And having to switch profiles to see all channels is ridiculous!
