- newapolloVery Insightful Person
Hi Just_Jay_92
Since you've just upgraded to a second box then it's likely that the Sky Cinema and Sky Sports codes have only been applied to one box.
Have you tried swapping the boxes around to see if the 100:70 fault follows the box? It might force an update of the channels (you won't lose them from the original box)
I would recommend calling the TV faults team on 0345 454 1111 option 1, 2 then 2 again and they will be able to look into adding those channels for you.
A member of the forum team may pick this up for you, but it may take a day or two.
I'm not sure if this will work but one workaround you can try whilst you are waiting for the channels to be updated is to record any programs from those channels that you are wanting to watch live, and see if you can play the recording on the second box.
- Ilyas_YForum Team (Retired)
Hey Just_Jay_92 Thanks for reaching out to us on the Virgin Media forums. 👋🏼
I'm sorry to hear about the issues with the TV channels you've has recently. 😢
Are you able to reboot the entire setup to see if they are then working? 🧾
If that doesn't work - can you try the advice given on this thread as well?
Let us know and we can go on from there.
Kind regards,
Ilyas.
Related Content
- 2 years ago
- 2 years ago
- 2 years ago
- 2 years ago
- 12 months ago
