on 25-05-2024 20:56
The shrill sound is emitted,usually, in the evening after a few hours use. I normally, watch breakfast tv until about 9..00 am , about 90 mins use, and then switched off until 12 noon. After continuous use until 5.00pm the fault starts to occur. The box does not feel hot. After 5.00pm every time I change channels using voice control a shrill sound is emitted, in addition this occurs when I delete a recording, manually,
I and not sure if the sound emits directly from the 360 or sondbar. Has anyone else noticed this?
Answered! Go to Answer
on 27-05-2024 15:32
on 26-05-2024 06:39
Is this a high pitch noise that occurs just as you change to some channels?
@Gavlar6 wrote:The shrill sound is emitted,usually, in the evening after a few hours use. I normally, watch breakfast tv until about 9..00 am , about 90 mins use, and then switched off until 12 noon. After continuous use until 5.00pm the fault starts to occur. The box does not feel hot. After 5.00pm every time I change channels using voice control a shrill sound is emitted, in addition this occurs when I delete a recording, manually,
on 26-05-2024 12:39
Hi, the sound occurs on all channels and also when using the rewind and forward buttons. It has now started to emit the sound all the time when using any function on the remote. To try to remedy the problem, I have switched off the 360, allowing it to cool, but with no change.
on 27-05-2024 11:22
Are you using a Panasonic tv?
on 27-05-2024 12:58
Yes, a TX-40EX700B.
on 27-05-2024 15:32
on 27-05-2024 16:32
Thank-you
on 27-05-2024 20:46
Thank-you
