pete37593's avatar
pete37593
Connection at rear of 360 box
What is the Scart connection at the rear of the box, is the USB port enabled?
Thanks.
  • Hi pete37593
    The scart socket is non-functional and is not connected.
    I run some multi-colour LED lights via the 360's USB port, however there isn't sufficient power on the port to charge a mobile or use a usb keyboard
1 Reply
    Hi pete37593
