d1avyt's avatar
d1avyt
Stream Box ITV1 HD Channel 103 no sound?
As the title says, this evening the sound has disappeared on ITV1 HD Channel 103 - but ONLY on that channel, all others appear to be working fine, including 870 ITV1 Anglia.
Anyone else getting similar?
I've rebooted the Stream box and VM bots reset the CM remotely, neither made any difference 🤷‍♂️
  • check the service status in the area, i know mine has a issue with ITV plus 1
  • We've got the same issue since yesterday. Rebooting made no difference. No reported service issues in our area (NW London).
    Please update if you've found a solution.
  • I have the same issue since yesterday afternoon. I’ve tried everything but no luck, also contacted Virgin and they said that there’s an issue in my area SE London, but when I checked, that only relates to ITV+1 which is working find for me.
    My issue is with ITV (103), I found a workaround, if you press the (…) on the remote, select Audio and choose Audio Description, you can get sound but you also have to put up with the AD but better than nothing.
    Hope this is sorted soon as it’s quite annoying.
  • The sound returned at some point yesterday evening. Hopefully it's OK fir others now.
  • Daniel_Et's avatar
    Daniel_Et
    Hi d1avyt 👋 Thank you for your post and welcome to the Virgin Media Community 😀
    We're sorry to hear about the problem you've been having 😔
    How have things been since you posted? Has the sound returned for you too?
    Regards,
    Daniel
