floppydog12's avatar
floppydog12
Sound level varies between channels
I have a V360 box feeding a Onkyo T NR 6100 AV amp. the sound level varies between channels and some times on the same channel between films sound level drops. On some occasions when I go to a channel and select the view from start the volume is lower than when watching live.  I have selected PCM 5.1 in audio output settings as had sound problem when follow content selected this switch changed levels slightly but still get variation in sound
  • Many thanks I routed audio via optic and it improved considerably no perfect but a lot better
  • Carley_S's avatar
    Carley_S
    Hi floppydog12
    Welcome to the community forums.
    Sorry to hear you're having issues with your sound levels at this time.
    Do you have a sound bar or any third party audio devices at all?
    • floppydog12's avatar
      floppydog12
      Yes I have a Onkyo AVV amp TX-6100 I have checked my settings on this and there are as they should be
        Nothing to do with VM TV as I don't use it, but I find this on all TV and streaming broadcasts.  It is really annoying to have to adjust the volume but I don't honestly believe this is particular to VM.
  • Had the same difficulty with my AV amp Onkyo. Had to route audio via Optical audio cable input rather than hdmi carrying sound. Much more stable.
      floppydog12
      • roy247's avatar
        roy247
        Hero
        If you want Dolby Atmos from the 360 you will need it connected by HDMI cable and the 360 set to follow content.
