on 12-06-2024 20:48
hub4 arrived the other day, and now I regret getting it
broadband was perfect before, upward of 100mbps all the time [on M250]
getting just 40odd mbps now even in the evening
tried using the old router, seems it wont now connect
why are things never simple?
are there any settings I can alter to try and get the speed back up?
12-06-2024 20:53 - edited 12-06-2024 20:53
What does this site show?
https://samknows.com/realspeed/
Assuming you are using WiFi your device could be using the 2.4Ghz band, rather than 5Ghz.
