on 14-04-2024 10:50
I had the 1Gb broadband service installed a few months ago, and other than a couple of outages all has been well. I have a Dream Machine SE which performs a daily speed test, and the results were always above 1Gbps down and 100Mbps up.
However, about two weeks I had a flashing blue light on the Virgin Hub (5X). The internet was still working so I’m not sure what a flashing blue light indicates on the 5X. Some suggestions where it may have been a firmware update, but that doesn’t seem to have been the case, and the flashing blue light remained until later that day when I restarted the hub.
Since having the flashing blue light, my daily speed test results have dropped significantly. The upload speed remains at 100+Mbps but my download results have dropped every day:
If I run a speed test then I usually get better results – 700/800+, but not the 1Gbps+ I was getting prior to the flashing blue light.
Any ideas?
on 14-04-2024 22:37
the only way to see if your speed is impacted is to check https://www.samknows.com/realspeed/
if thats fine then its a local issue, blue flashing usually means its updating isnt it? not 100% sure though.
15-04-2024 08:56 - edited 15-04-2024 09:35
RealSpeed results:
(Download results - Router: 373 - Device: 339)
As for the flashing blue light, a firmware update was my assumption, but it was flashing all day before I finally rebooted it.
on 15-04-2024 10:53
Does the faults in your street service : 0800 561 0061 cover XGS-PON connections ?
on 15-04-2024 11:23
I've tried the faults service number and nothing reported.
on 15-04-2024 21:56
thats definitly not 1gig, although it is on the package, get someone out, it could be a dirty connector.
16-04-2024 08:38 - edited 16-04-2024 08:47
Would a dirty connector also affect the upload?
Todays results...
Speed tests performed by the DM SE over the last few days:
and todays RealSpeed test:
It's getting worse every day.
16-04-2024 11:12 - edited 16-04-2024 11:13
So much for customer support.... after spending over 2 hours trying to speak to someone @ VM about this issue, I finally get put through to the 5X support team, who are then insistent that I have a wifi issue, even after I told them wifi on the hub is turned off and I am performing my speed tests from a machine directly connected to the hub!
I'm livid!
on 16-04-2024 11:25
I guess that we are in the same boat (see https://community.virginmedia.com/t5/Speed/Sudden-drop-in-SamKnows-RealSpeed-to-router/td-p/5510724), although I did not get or did not notice a flashing blue light on the 5x, after a couple of reboots it is staying solid white. The realspeed tests strongly suggest that it is something that VM have done or are in the process of doing, could be routing issues or unsuccessful attempts at firmware upgrades. I doubt that it is dirty connectors, mine have not been touched for months.
on 16-04-2024 11:37
The flashing blue light may just be coincidence, and after spending hours going round in circles trying to contact VM, I did find a support page that suggests that a flashing blue light indicates that WPS has been triggered, but as I have wifi disabled on the hub it's anyone's guess as to what it meant!
I'm a relatively new install as VM only came live in this area (YO32) in January
