danbish
11 months agoOn our wavelength
Replacement hub, slow speeds
Hi.
I've recently had an issue with red light on my Hub 3 (https://community.virginmedia.com/t5/Networking-and-WiFi/Red-light-on-Hub-3/m-p/5589402#M599039) which has been solved by an engineer visit this afternoon who's changed the hub for another Hub 3.
My contract with VM is for M250 broadband but the speeds I'm getting from this hub are particularly slow. Instead of the 200-250Mbs I was getting with the old hub, this new one is giving me 9.4 which is drastically short. Is this normal with a new hub - slow to start but will pick up later, or should the speed instantly be the same as before as I'm thinking?
The test has been done at Speedtest.net where I usually go and my PC is wired to the hub.
Thanks!
