on 27-03-2024 04:05
Which would be better and faster. I am. Looking for the beet connection possible I do have both these devices on hand but which would you use as a consumer or a technical person.
The extender in ap mode is tplink ax1500 with wifi 6. At the moment all my devices are wifi 5 but nest time I buy one I'll look for minimum wifi 6 and wifi 6.hub 5.ill get.
When I get hub.5 I'll order the black wifi 6 pods which shoukd help over white pods.
a month ago
Have you tried modem mode and using the TP Link as your router?
a month ago
If you can get the pods free as part of your package I would give them a try, but if you have to pay for them it’s a no brainier, other wireless access points are nearly always better.
