on 07-03-2023 12:33
Ive been with VM for about 4-5 years and have never had an issue. Since yesterday my work laptop, on which I have to use a VPN to access the hospital systems is losing connection every few minutes, making working from home almost impossible.
I have a hub 3, all other devices are working normally. My work IT help desk say there is nothing wrong with the laptop or at the hospital end but think it may be something to do with Virgin?
Any help very much appreciated
on 04-01-2024 19:21
Hi there,
Could you possibly share your fix? I'm experiencing the same issues.
Any help would be amazing!
Thank you,
Tom
on 04-01-2024 19:25
Hello,
I had to log in to the router and do something to the DMV (demilitarised zone). The IT manager from my neighbouring NHS talked me through it. I had to give the DMV my laptop IP or network ID from memory. I actually ditched Virgin and moved to BT after due to costs.
Lois
on 04-01-2024 19:35
Hello,
Thank you for the info! Has your trust laptop connected fine to BT?
Tom
on 04-01-2024 20:46
Yes it seems to be fine with BT. Are you also NHS?
Lois
on 04-01-2024 20:57
Hey Lois,
No, but my girlfriend is and we've just had Virgin installed, but I think we will move to BT.
Thank you for your help, really appreciate it!
on 04-01-2024 20:59
Hi Tom,
Which Trust? I work in Procurement for both Bristol Trusts and Bath NHS helped me. We believe it’s something to do with the security some Trusts use. There may be others in your girlfriends Trust having issues, Bristol and Bath had discussed meeting together with Virgin to discuss, they’d likely discuss with your GFs Trust too.
Lois
