3 weeks ago
i posted a couple of days ago when having an area outage - it was fixed (according to all service pages and phone number automated thing).
however ive checked the hub in modem mode and the stats look crazy. eg
(now i know a bit about networking but not sure what ranges are healthy but id say these are mental - and am i right in thinking lowest is best - some channels have millions / 100s of thousands.
Acquired Downstream Channel (Hz) | 139000000 | Locked |
Ranged Upstream Channel (Hz) | 36600025 | Locked |
Provisioning State | Online |
downstream
1 | 139000000 | 3 | 38 | 256 qam | 1 |
2 | 147000000 | 3 | 38 | 256 qam | 2 |
3 | 155000000 | 2.7 | 38 | 256 qam | 3 |
4 | 163000000 | 2.7 | 38 | 256 qam | 4 |
5 | 171000000 | 2.7 | 38 | 256 qam | 5 |
6 | 179000000 | 2.9 | 38 | 256 qam | 6 |
7 | 187000000 | 2.5 | 38 | 256 qam | 7 |
8 | 195000000 | 2.4 | 38 | 256 qam | 8 |
9 | 203000000 | 2.4 | 38 | 256 qam | 9 |
10 | 307000000 | 2.7 | 38 | 256 qam | 22 |
11 | 315000000 | 2.7 | 38 | 256 qam | 23 |
12 | 323000000 | 2.7 | 38 | 256 qam | 24 |
13 | 331000000 | 2.7 | 38 | 256 qam | 25 |
14 | 339000000 | 2.7 | 38 | 256 qam | 26 |
15 | 347000000 | 2.4 | 38 | 256 qam | 27 |
16 | 355000000 | 1.9 | 38 | 256 qam | 28 |
17 | 363000000 | 2 | 38 | 256 qam | 29 |
18 | 371000000 | 2 | 38 | 256 qam | 30 |
19 | 379000000 | 1.4 | 38 | 256 qam | 31 |
20 | 387000000 | 1.5 | 38 | 256 qam | 32 |
21 | 395000000 | 1.2 | 38 | 256 qam | 33 |
22 | 403000000 | 1.2 | 38 | 256 qam | 34 |
23 | 411000000 | 1.7 | 38 | 256 qam | 35 |
24 | 419000000 | 1.9 | 38 | 256 qam | 36 |
1 | Locked | 38.6 | 2637652 | 8623675 |
2 | Locked | 38.9 | 22934241 | 6853426 |
3 | Locked | 38.9 | 6593331 | 51477 |
4 | Locked | 38.9 | 250472 | 15667 |
5 | Locked | 38.9 | 168926 | 31332 |
6 | Locked | 38.9 | 114634 | 29050 |
7 | Locked | 38.6 | 138131 | 23774 |
8 | Locked | 38.6 | 172060 | 8740 |
9 | Locked | 38.9 | 132791 | 2129 |
10 | Locked | 38.9 | 20 | 0 |
11 | Locked | 38.6 | 33 | 0 |
12 | Locked | 38.9 | 15 | 0 |
13 | Locked | 38.9 | 6 | 0 |
14 | Locked | 38.9 | 4 | 0 |
15 | Locked | 38.6 | 5 | 0 |
16 | Locked | 38.9 | 15 | 0 |
17 | Locked | 38.9 | 12 | 0 |
18 | Locked | 38.6 | 8 | 0 |
19 | Locked | 38.9 | 12 | 0 |
20 | Locked | 38.9 | 10 | 0 |
21 | Locked | 38.9 | 12 | 0 |
22 | Locked | 38.9 | 9 | 0 |
23 | Locked | 38.6 | 11 | 0 |
24 | Locked | 38.6 | 6 | 0 |
UP
1 | 36600025 | 45 | 5120 | 32 qam | 3 |
2 | 23600282 | 44.5 | 5120 | 32 qam | 5 |
3 | 49600000 | 46.5 | 5120 | 64 qam | 1 |
4 | 30100166 | 45.8 | 5120 | 64 qam | 4 |
5 | 43100005 | 45.3 | 5120 | 64 qam | 2 |
1 | ATDMA | 0 | 0 | 6 | 0 |
2 | ATDMA | 0 | 0 | 6 | 0 |
3 | ATDMA | 0 | 0 | 1 | 0 |
4 | ATDMA | 0 | 0 | 3 | 0 |
5 | ATDMA | 0 | 0 | 3 | 0 |
engineer is booked in tomorrow - 12-4
is there anything i can suggest to them - because ive read some posts and a lot say they just swap out hub and /or blame it on my side of stuff (im in modem mode, with a tested on other networks router, that i know is solid).
thanks
3 weeks ago - last edited 3 weeks ago
what does a BQM show?
Broadband Quality Monitor | thinkbroadband
3 weeks ago
Far too many PostRS errors and two of the US channels are running 32 QAM. This would suggest noise ingress somewhere in the circuit. You will need a VM technician to sort this out.
Also VM will insist the Hub be placed in Router mode before they will do any investigations as they say they can't do diagnostics when the Hub is in Modem mode, apparently.
3 weeks ago
<a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/a563d36cefe58a4c3630de928052bf3310478310-21-08-2024"><img alt="My Broadband Ping - aug 24 - 2nd" src="https://www.thinkbroadband.com/broadband/monitoring/quality/share/a563d36cefe58a4c3630de928052bf3310478310-21-08-2024.png" /></a>
3 weeks ago
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/a563d36cefe58a4c3630de928052bf3310478310-21-08-2024][img]https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/a563d36cefe58a4c3630de928052bf3310478310-21-08-2024.png[/img][/url]
3 weeks ago
Thanks for reaching out to us @skylineboy2002 and we're sorry to hear of the intermittent service you've been experiencing, with drops in the connection evident on the BQM links.
I understand that this issue has been diagnosed and we're in the process of attempting to resolve this matter for you.
Do please keep us updated and we'll be on hand to assist where needed.
David_Bn
2 weeks ago
i have been told i need a "cable pull" and this is obviously more of a ground crew issue and not engineer.
engineer said approx 7-14 days.
but will someone be in touch when it will happen? or will they just do it (as its an outside issue, eg road / cabinet to my outside walls)?
if possible i'd like to know when it may happen so i can be there, and can see if it fixes issue.
2 weeks ago
A cable repull (if the old co-ax) will not need you in as it's from the street cab to the exterior wall box on your property. A technician should be sent afterwards to sort out any power level issues etc. The tech will need access to your property at that time.
a week ago
Hey skylineboy2002, thank you for reaching out and I am sorry you are waiting on a pre pull.
Normally you get a SMS or a call from the team with a timing and date.
Have you heard or got anything from us at all?
Matt - Forum Team
New around here?
