pwhatcher's avatar
pwhatcher
Low download speed
I'm on the 1Gb package and upload is generally good but download rarely breaks 300Mb and is typically 100-250Mb
Here's the stats
3.0 Downstream channels
1 306000000 4.7 41 QAM 256 22
2 138000000 5.9 41 QAM 256 1
3 146000000 5.7 41 QAM 256 2
4 154000000 5.4 41 QAM 256 3
5 162000000 5.5 41 QAM 256 4
6 170000000 5.3 41 QAM 256 5
7 178000000 4.8 41 QAM 256 6
8 186000000 4.8 41 QAM 256 7
9 194000000 4.9 41 QAM 256 8
10 202000000 4.6 41 QAM 256 9
11 210000000 5.1 41 QAM 256 10
12 218000000 4.8 41 QAM 256 11
13 226000000 4.6 41 QAM 256 12
14 234000000 5 41 QAM 256 13
15 242000000 4.8 41 QAM 256 14
16 250000000 4.2 41 QAM 256 15
17 258000000 4.6 41 QAM 256 16
18 266000000 4.4 41 QAM 256 17
19 274000000 4.2 41 QAM 256 18
20 282000000 4.8 41 QAM 256 19
21 290000000 4.9 41 QAM 256 20
22 298000000 4.3 40 QAM 256 21
23 314000000 4.5 41 QAM 256 23
24 322000000 4.3 41 QAM 256 24
25 330000000 4.7 41 QAM 256 25
26 338000000 4.8 41 QAM 256 26
27 346000000 4.5 41 QAM 256 27
28 354000000 4.5 41 QAM 256 28
29 362000000 3.9 41 QAM 256 29
30 370000000 3.2 41 QAM 256 30
31 378000000 3.7 41 QAM 256 31
1 Locked 41 0 0
2 Locked 41 0 0
3 Locked 41 0 0
4 Locked 41 0 0
5 Locked 41 0 0
6 Locked 41 0 0
7 Locked 41 0 0
8 Locked 41 0 0
9 Locked 41 0 0
10 Locked 41 0 0
11 Locked 41 0 0
12 Locked 41 0 0
13 Locked 41 0 0
14 Locked 41 0 0
15 Locked 41 0 0
16 Locked 41 0 0
17 Locked 41 0 0
18 Locked 41 0 0
19 Locked 41 0 0
20 Locked 41 0 0
21 Locked 41 0 0
22 Locked 40 0 0
23 Locked 41 0 0
24 Locked 41 0 0
25 Locked 41 0 0
26 Locked 40 0 0
27 Locked 41 0 0
28 Locked 41 0 0
29 Locked 41 0 0
30 Locked 41 0 0
31 Locked 41 0 0
3.1 Downstream channels
159 92 4K 1800 QAM 4096 1128
159 Locked 42 3.5 22561186 0
0 Upstream channels
0 49600000 44.5 5120 QAM 64 1
1 43100000 43.8 5120 QAM 64 2
2 36600000 43 5120 QAM 64 3
3 30100000 43 5120 QAM 64 4
4 23600000 43 5120 QAM 64 5
3.0 Upstream channels
0 ATDMA 0 0 0 0
1 ATDMA 0 0 2 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
3.1 Upstream channels
6 10 38.5 2K QAM 256
6 OFDMA 200 74000000 0 0
Don't know if the network log errors have any bearing...
03-02-2024 19:10:15 notice US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-02-2024 19:10:15 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-02-2024 19:10:11 notice REGISTRATION COMPLETE - Waiting for Operational status
03-02-2024 19:10:05 warning Dynamic Range Window violation
03-02-2024 19:10:05 warning REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-02-2024 19:10:05 warning RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-02-2024 19:10:05 warning RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-02-2024 19:09:59 notice DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-02-2024 19:09:51 warning DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-02-2024 19:09:49 notice Honoring MDD; IP provisioning mode = IPv4
03-02-2024 19:09:37 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-02-2024 19:09:31 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-02-2024 19:09:30 critical Cable Modem Reboot because of - HW or Power-On Reset
03-02-2024 18:56:29 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-02-2024 18:56:23 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-02-2024 18:56:22 critical Cable Modem Reboot because of - Reboot Timezone Change
03-02-2024 18:53:20 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-02-2024 18:53:15 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-02-2024 18:53:14 critical Cable Modem Reboot because of - pin-reset
  • Wired, here's the BQM
    https://www.thinkbroadband.com/broadband/monitoring/quality/share/e01cc9172c8c7d0725ee36d6f1ae0838cbb48c59-05-02-2024
    • Carley_S's avatar
      Carley_S
      Hi pwhatcher
      Welcome back to the community forums
      Sorry to hear you're having some issues with your speeds at this time.
      I have checked what I can on my side and cannot see any issues with your routers specs and the area also looks good.
      Are you running any third party networking equipment at all?
      What results did you get on the test kindly advised by legacy1?
  • legacy1's avatar
    BQM has spikes but nothing that would slow your speed
    In router mode I take it?
    Can you do send a file from one PC to another by wire to see what speed you get.
