TiPs1's avatar
TiPs1
Is my power levels to blame for my poor connection?
Morning everyone.
I previously had issues before and it will resolved after a repull and power levels adjusted but yet again I am having issues. I have been running a BQM for the past few days which looks ok I believe with a blip on Wednesday evening.
The problem I have noticed is streaming, Its not streaming to the full quality and this is happening on Amazon Prime/Netflix and Youtube all on a wired connection with 1Gig connection.
I also have Google Home Doorbell and outdoor camera's and these are the same they take around 5/10 seconds before the stream shows a clear image instead of blured but obviously these are on WiFi but never had any issues previously.
I am wondering if my power levels are causing issues yet again?
Cable Modem StatusItemStatusTypeCable Modem StatusOnlineDOCSIS 3.0Primary downstream channelLockedSC-QAMChannel OverviewDownstreamUpstreamDOCSIS 3.0 channels325DOCSIS 3.1 channels11
3.0 Downstream channels
119500000010.841QAM 2568
213900000011.540QAM 2561
314700000011.340QAM 2562
415500000010.840QAM 2563
516300000010.641QAM 2564
617100000010.641QAM 2565
717900000010.441QAM 2566
818700000010.541QAM 2567
920300000010.541QAM 2569
1021100000010.641QAM 25610
1121900000010.741QAM 25611
1222700000010.541QAM 25612
1323500000010.341QAM 25613
142430000001041QAM 25614
152510000009.641QAM 25615
162590000009.741QAM 25616
172670000009.741QAM 25617
182910000009.641QAM 25620
192990000009.941QAM 25621
203230000009.541QAM 25624
213550000009.541QAM 25628
223630000009.141QAM 25629
233790000008.141QAM 25631
243870000007.541QAM 25632
253950000007.641QAM 25633
26403000000841QAM 25634
274110000007.841QAM 25635
284190000007.841QAM 25636
294270000008.341QAM 25637
304350000008.141QAM 25638
314430000007.941QAM 25639
324510000008.441QAM 25640
1Locked41410
2Locked40500
3Locked40540
4Locked40800
5Locked41430
6Locked41730
7Locked41610
8Locked41410
9Locked41450
10Locked41350
11Locked41520
12Locked41450
13Locked41430
14Locked41460
15Locked41460
16Locked41450
17Locked41470
18Locked41480
19Locked41530
20Locked41670
21Locked41430
22Locked41440
23Locked41730
24Locked41950
25Locked41850
26Locked41730
27Locked41700
28Locked41790
29Locked41550
30Locked41570
31Locked41830
32Locked41860
3.1 Downstream channels
159944K1840QAM 40961108
159Locked426.69878927710
3.0 Upstream channels
049600000455120QAM 641
143100000445120QAM 642
23660000043.35120QAM 643
33010000042.55120QAM 644
423600000425120QAM 645
0ATDMA0000
3ATDMA0000
4ATDMA0000
3.1 Upstream channels
61039.52KQAM 256
6OFDMA20074000000540
  • Network Log
    12-07-2024 10:27:43noticeGUI Login Status - Login Success from LAN interface
    11-07-2024 14:39:11warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    11-07-2024 14:39:11noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    11-07-2024 13:35:17noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    11-07-2024 13:35:17warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    11-07-2024 13:34:52warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    11-07-2024 13:34:52noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    10-07-2024 19:00:08noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    10-07-2024 19:00:08warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    10-07-2024 17:50:03warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    10-07-2024 17:50:03noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    09-07-2024 17:07:27warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    09-07-2024 17:07:27noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    09-07-2024 15:57:55warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    09-07-2024 15:57:55noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    09-07-2024 11:04:39noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    09-07-2024 11:04:39warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    09-07-2024 09:54:37warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    09-07-2024 09:54:37noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    09-07-2024 04:57:26errorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    09-07-2024 02:30:01noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    09-07-2024 02:30:01warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    09-07-2024 01:21:38warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    09-07-2024 01:21:38noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    09-07-2024 01:19:31noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    09-07-2024 01:19:31warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    09-07-2024 00:19:07warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    09-07-2024 00:19:07noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    08-07-2024 22:28:03warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    08-07-2024 22:28:03noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    08-07-2024 21:27:51noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    08-07-2024 21:27:51warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    08-07-2024 15:55:14warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    04-07-2024 07:24:15noticeGUI Login Status - Login Success from LAN interface
    04-07-2024 07:24:07noticeGUI Login Status - Login Success from LAN interface
    04-07-2024 07:23:27noticeGUI Login Status - Login Success from LAN interface
    BQM Link: https://www.thinkbroadband.com/broadband/monitoring/quality/share/7e3ddb2ea50f2211cb56429e1c5dd32fb7a21375
  • legacy1's avatar
    likely the CDN to you is over loaded
    also router mode and wifi on the hub not that good
    • TiPs1's avatar
      TiPs1
      The router and wifi have been fine for me only within the last week its been playing up and its getting beyond a joke.
      • Matthew_ML's avatar
        Matthew_ML
        Hey Tips1, thank you for reaching out and I am so sorry to hear about this.
        I've taken a look from our side and everything is looking fine, how has it been over the weekend?
        Have you seen an improvement?
