Intermittent signal, daily disconnections
bugsbungee
Hi, for the past few months we’ve been getting increasingly frequent drop outs of our broadband. I think it’s been happening since the volt upgrade (1gig was fine before that as far as I recall). Rebooting the modem sometimes fixes it but it has become a real problem as I work from home (have done for six years but this is the first real issue).
Today the issues have been constant since about 6pm where we were watching some streaming series and it all went Pete tong.
here are some of the logs
Fri 24/03/2023
20:20:51
6US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: .;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/03/2023
20:11:58
5DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/03/2023
20:11:41
5MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/03/2023
20:08:14
4DBC-ACK not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/03/2023
20:08:12
Fri 24/03/2023
20:07:12
Fri 24/03/2023
20:06:45
Fri 24/03/2023
19:35:44
Fri 24/03/2023
19:34:43
Fri 24/03/2023
19:34:41
Fri 24/03/2023
19:32:37
Fri 24/03/2023
19:01:09
Fri 24/03/2023
19:00:45
Fri 24/03/2023
18:59:45
Fri 24/03/2023
18:59:42
Fri 24/03/2023
18:58:42
Fri 24/03/2023
18:58:39
Fri 24/03/2023
18:57:39
Fri 24/03/2023
18:57:36
Fri 24/03/2023
18:56:36
Fri 24/03/2023
18:56:33
Fri 24/03/2023
18:54:30
Fri 24/03/2023
18:54:27
6US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/03/2023
18:22:53
Fri 24/03/2023
18:22:26
Fri 24/03/2023
18:19:57
Fri 24/03/2023
11:49:08
Fri 24/03/2023
11:44:12
6DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/03/2023
11:44:12
4DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 23/03/2023
09:18:34
6US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 23/03/2023
09:08:14
3No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 23/03/2023
04:17:51
Thu 23/03/2023
04:05:38
Wed 22/03/2023
11:47:16
Wed 22/03/2023
11:23:27
Tue 21/03/2023
04:12:08
Tue 21/03/2023
03:57:17
Tue 21/03/2023
03:00:53
Tue 21/03/2023
01:59:11
Mon 20/03/2023
23:44:43
Mon 20/03/2023
23:44:26
Mon 20/03/2023
23:40:30
5Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 20/03/2023
23:40:27
6CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 20/03/2023
23:40:24
3SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 20/03/2023
23:22:25
Mon 20/03/2023
23:22:25
Mon 20/03/2023
18:06:35
Mon 20/03/2023
17:13:38
Mon 20/03/2023
16:05:36
Mon 20/03/2023
15:45:06
3
21 REPLIES 21
A National outage that’s been going on for about 4 months?
Reece_MH
Hi bugsbungee 👋
Thanks for providing an update - I'm sorry to hear things still aren't working very well. I've taken a look on our side and I can't see any problems with the levels at your Hub - they're all within standard specifications. However, I can see that you currently have Modem Mode active on your service, which can limit further diagnostics, and also could be the cause of the problem (for example, your own equipment has a fault).
Are you able to set your Hub into Router Mode to see if this improves the issues you're facing?
Reece - Forum Team
New around here? To find out more about the Community check out our FAQ
I have yes, it makes no difference which mode it’s in, I get the intermittent disconnects and the same corresponding log message. I have a technician booked now to try swapping the hub out as it could be faulty hardware.
Zoie_P
Hi @bugsbungee 👋,
Thank you for your post and I am sorry you are still having issues. Can you please come out of modem mode so we can run some diagnostics from our systems?
Zoie
 No problem, it’s in router mode now.
Hi bugsbungee,
Thanks for coming back to us on this one.
I've run some checks on the hub now and can see all signal and power levels are optimal. No disconnections have been recorded since the hub was taken out of modem mode.
I can see you already have an engineer visit booked so we will wait the outcome of this. Please post back here and let us know how it goes.
Many thanks,
Kath_F
Definitely not resolved by router mode, can I also add I’ve used modem mode for many years and with prior modems with no issue, this is a very recent problem. Engineer on Monday but here’s the latest. I also reached out to Eero who can see router logs and they see the internet disconnections as well (sadly the router logs are not consumer accessible).
Log
Sat 15/04/2023
03:32:46
Sat 15/04/2023
03:16:50
Fri 14/04/2023
15:54:43
Fri 14/04/2023
15:45:22
Fri 14/04/2023
08:00:51
Fri 14/04/2023
07:46:40
Fri 14/04/2023
03:00:03
Fri 14/04/2023
02:38:36
Thu 13/04/2023
23:24:05
Thu 13/04/2023
23:03:13
Thu 13/04/2023
20:09:47
Thu 13/04/2023
20:00:08
Thu 13/04/2023
18:54:38
Thu 13/04/2023
18:54:38
Thu 13/04/2023
17:52:32
Thu 13/04/2023
10:54:30
Thu 13/04/2023
10:18:24
Thu 13/04/2023
03:55:18
Thu 13/04/2023
03:55:01
Thu 13/04/2023
00:48:34
6US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 13/04/2023
00:04:15
Thu 13/04/2023
00:04:15
Wed 12/04/2023
23:07:37
Wed 12/04/2023
23:07:37
Wed 12/04/2023
14:04:09
Wed 12/04/2023
13:06:46
Wed 12/04/2023
04:58:15
Wed 12/04/2023
04:47:00
Tue 11/04/2023
23:33:14
Tue 11/04/2023
23:33:14
Tue 11/04/2023
20:24:51
Tue 11/04/2023
19:58:51
Tue 11/04/2023
19:53:28
Tue 11/04/2023
19:37:33
Tue 11/04/2023
18:30:22
Tue 11/04/2023
18:24:20
Tue 11/04/2023
17:58:48
Tue 11/04/2023
17:54:03
Tue 11/04/2023
10:40:22
Tue 11/04/2023
10:26:46
Tue 11/04/2023
10:24:59
Tue 11/04/2023
10:23:46
Tue 11/04/2023
02:13:39
Tue 11/04/2023
01:44:16
Tue 11/04/2023
00:02:17
Tue 11/04/2023
00:00:46
Mon 10/04/2023
16:39:53
Mon 10/04/2023
16:22:30
Mon 10/04/2023
12:06:34
Mon 10/04/2023
12:06:33
Thanks for coming back to us bugsbungee, how did the visit today go, has the technician been able to resolve the issues that you've been having?
Kind Regards,
Steven_L
Hi did you ever get this resolved I’m having exactly the same issues
After many postponed tech visits I eventually got a super hub 5 installed. For about a week things were ok but now we’re back to the same issues. It’s definitely an area problem and quite intermittent. Fttp is coming to my area soon so I’ll 100% be switching to that
