Hope for massive improvement after ridiculous price increase from april
broksonic
Fibre optic
500mb and only getting  107 😳
8 REPLIES 8
Maybe you have something downloading?
Test in modem mode
carl_pearce
Community elder
What does this site show?
https://samknows.com/realspeed/
You should be testing using a wired device, not wireless.
Downloading nothing
broksonic
Fibre optic
Strange I had 545 the other day testing using WiFi.
ozsat
Superstar
If you wifi is high then my guess is the device only has the standard 100Mpbs network card or it is only configured for 100Mbps.
The VM speed you pay for is the speed to your hub - anything connected to the hub is for the user to resolve.
https://samknows.com/realspeed/ shows you the speed to your hub and also the speed to your device from the hub,
1.2Gb/100Mb in Oxford (area 31) using SH5
jpeg1
OP hasn't tested over ethernet, so network card is not relevant.
- jpeg1
My name is NOT Alessandro. That's just a tag Virginmedia sticks on some contributors. Please ignore it.
They didn't say how the 100M test was done but said got 500M on Wifi.
But without Samknows results I woud assume the issue in in-house.
jpeg1
Both the speedtests posted were done over WiFi.  Check the icon in the corner.
- jpeg1
