southy1978's avatar
southy1978
10 months ago
High latency & connection constantly dropping out
Hi, I am having a lot of issues with my Gig1 connection. It is constantly giving high latency and the connection drops out and is non responsive. Is anyone able to check my hub values and confirm whether i have an issue?
I have rebooted the hub several times, Checked all cabling is tight & undamaged.
Item Status TypeChannel Overview Downstream Upstream
Cable Modem StatusOnlineDOCSIS 3.0
Primary downstream channelLockedSC-QAM
DOCSIS 3.0 channels325
DOCSIS 3.1 channels11
3.0 Downstream channels
11390000005.740QAM 2561
21470000005.640QAM 2562
31550000005.340QAM 2563
4163000000540QAM 2564
51710000004.840QAM 2565
61790000004.840QAM 2566
71870000004.940QAM 2567
81950000005.140QAM 2568
92030000004.940QAM 2569
10211000000540QAM 25610
112190000004.840QAM 25611
122270000004.540QAM 25612
132350000004.440QAM 25613
142430000004.240QAM 25614
15251000000440QAM 25615
16259000000440QAM 25616
172670000004.140QAM 25617
182750000004.240QAM 25618
192830000004.240QAM 25619
202910000004.140QAM 25620
21299000000440QAM 25621
22307000000440QAM 25622
233150000003.940QAM 25623
243230000003.840QAM 25624
253310000003.740QAM 25625
26339000000440QAM 25626
273470000004.240QAM 25627
283550000004.341QAM 25628
293630000004.541QAM 25629
303710000004.641QAM 25630
313790000004.941QAM 25631
323870000004.841QAM 25632
1Locked403771
2Locked401900
3Locked401320
4Locked401100
5Locked40960
6Locked40800
7Locked40800
8Locked40710
9Locked4010712
10Locked4012726
11Locked4012623
12Locked401273
13Locked40951
14Locked40891
15Locked401052
16Locked40890
17Locked40910
18Locked40861
19Locked40530
20Locked40650
21Locked40660
22Locked40490
23Locked40560
24Locked40680
25Locked40670
26Locked40760
27Locked40550
28Locked41550
29Locked41670
30Locked41570
31Locked41580
32Locked41500
  • southy1978's avatar
    southy1978
    3.1 Downstream channels
    159944K1840QAM 40961108
    159Locked423.51632719161750
    southy1978
    3.0 Upstream channels
    049600000475120QAM 641
    14310000046.85120QAM 642
    23660000046.55120QAM 643
    330100000465120QAM 644
    42360000045.35120QAM 645
    0ATDMA03140
    1ATDMA03200
    2ATDMA0360
    3ATDMA03210
    4ATDMA03160
    3.1 Upstream channels
    61041.72KQAM 256
    6OFDMA20074000000670
    southy1978
    27-11-2024 15:17:51noticeGUI Login Status - Login Success from LAN interface
    27-11-2024 14:50:34noticeGUI Login Status - Login Success from LAN interface
    27-11-2024 14:45:32warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-11-2024 14:45:32noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-11-2024 14:25:18warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-11-2024 14:25:18noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-11-2024 13:55:01warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-11-2024 13:55:01noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-11-2024 13:34:49noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-11-2024 13:34:49warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-11-2024 07:01:46noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-11-2024 07:01:46warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-11-2024 06:41:38warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-11-2024 06:41:38noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-11-2024 17:05:08noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-11-2024 17:05:08warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-11-2024 16:55:01warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-11-2024 16:55:01noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-11-2024 16:24:47warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-11-2024 16:24:47noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-11-2024 16:14:44noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-11-2024 16:14:44warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-11-2024 15:44:31noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-11-2024 15:44:31warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-11-2024 15:34:26noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-11-2024 15:34:26warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-11-2024 11:52:36noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-11-2024 11:52:36warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-11-2024 11:42:29noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-11-2024 11:42:29warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-11-2024 10:11:55warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-11-2024 10:11:55noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-11-2024 10:01:47noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    26-11-2024 10:01:47warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
  • legacy1's avatar
    Just the way it is with upstream tell people in your area to not upload much
      southy1978
      Is it bad? Does it look like i would require an engineer visit?
      • David_Bn's avatar
        David_Bn
        Thanks for reaching out to us southy1978, and welcome back to our Community Forums!
        Sorry to hear of the recent issues experienced on the connection supplied by Virgin Media.
        Can you confirm if the issue raised is still ongoing?
        When running through a flow on your router, no issues appear to be detected on your connection.
        David_Bn
