Check Signal Levels please - friend having issues
Spitfire16
Up to speed
Can someone please check the below signal levels please as my friend is having intermittent connection
Downstream
15140000003.842QAM 25636
21780000002.942QAM 2566
31860000002.842QAM 2567
41940000002.942QAM 2568
52020000002.942QAM 2569
62100000003.342QAM 25610
72180000003.442QAM 25611
82260000003.442QAM 25612
92340000003.142QAM 25613
102420000002.942QAM 25614
112500000002.942QAM 25615
12258000000342QAM 25616
132660000003.242QAM 25617
142740000003.342QAM 25618
152820000003.342QAM 25619
162900000003.542QAM 25620
172980000003.642QAM 25621
183060000003.542QAM 25622
193140000003.542QAM 25623
203220000003.543QAM 25624
213300000003.543QAM 25625
223380000003.743QAM 25626
233460000003.743QAM 25627
243540000003.642QAM 25628
253620000003.542QAM 25629
263700000003.542QAM 25630
273780000003.542QAM 25631
283860000003.543QAM 25632
293940000003.542QAM 25633
304020000003.542QAM 25634
314100000003.743QAM 25635
3.0 Downstream channels
1Locked42760
2Locked4220
3Locked4210
4Locked4240
5Locked4210
6Locked4210
7Locked4200
8Locked4210
9Locked4210
10Locked4230
11Locked4220
12Locked4210
13Locked4200
14Locked4240
15Locked4210
16Locked4200
17Locked4200
18Locked4200
19Locked4200
20Locked4320
21Locked4300
22Locked4310
23Locked4300
24Locked4250
25Locked4200
26Locked4210
27Locked4230
28Locked4320
29Locked4220
30Locked4210
31Locked43269413071
3.1 Downstream channels
159944K1840QAM 40961108
159Locked423.45324015160
Upstream
3.0 Upstream channels
04960000048.55120QAM 641
14310000048.35120QAM 642
23660000048.35120QAM 643
33010000048.35120QAM 644
42360000047.85120QAM 645
0ATDMA0000
3ATDMA0000
4ATDMA0000
3.1 Upstream channels
61042.52KQAM 256
6OFDMA2007400000000
18-01-2024 18:23:28warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-01-2024 18:23:28noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-01-2024 11:08:42noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-01-2024 11:08:42warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-01-2024 10:04:07noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-01-2024 10:04:07warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-01-2024 23:02:29warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-01-2024 23:02:29noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-01-2024 23:02:22noticeREGISTRATION COMPLETE - Waiting for Operational status
17-01-2024 23:02:16warningDynamic Range Window violation
17-01-2024 23:02:16warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-01-2024 23:02:16warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-01-2024 23:02:16warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-01-2024 23:02:10noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-01-2024 23:02:03warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-01-2024 23:02:01noticeHonoring MDD; IP provisioning mode = IPv4
17-01-2024 23:01:46criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-01-2024 23:01:45criticalCable Modem Reboot because of - HW or Power-On Reset
08-01-2024 04:02:04criticalRanging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
08-01-2024 04:02:04critical16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
08-01-2024 04:01:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
08-01-2024 02:04:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
08-01-2024 01:15:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
08-01-2024 01:15:03criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
08-01-2024 01:14:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
08-01-2024 01:14:24criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
08-01-2024 01:14:02criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
4 REPLIES 4
Cardiffman282
Trouble shooter
Downstream channel 31 is struggling with post RS errors.
Cancel VM here
Complain to VM
here
Demand compensation from VM here
Demand your call recordings here
Monitor the state of your VM connection here
Beth_G
Hi Spitfire16
Sorry to hear your friend is having issues with their broadband - thanks for your post.
We'll drop you a PM so we can take their details from you and take a closer look for you. But yes, as Cardifman282 has advised, there is an issue on one of the channels.
Look out for my message 😊
Beth
Hi Beth , tried to PM you back but its not allowing me?
Hi @Spitfire16
Beth has received your PM and will respond as soon as possible 😊
Thanks!
Ayisha_B
