on 01-11-2023 10:45
Hi all
I will be getting my new Hub 4 today and was wondering how easy it is to set it up. Can I backup the config from the Hub 3 and restore it to the Hub 4? I have a range extender. Connected to this are a ring doorbell, and chime and I would like to avoid going through the process of re-joining everything as it was a pain the first time round.
James
Answered! Go to Answer
on 01-11-2023 10:50
You cannot retore a fimrware backup from different Hubs. However, you should be able to change the SSID and password on the Hub 4 to the same as you used on the Hub 3. As for the physical change over, yes it's just a matter of removing the Hub 3 and replace with the Hub 4. The co-ax connections are the same.
on 01-11-2023 10:50
on 03-11-2023 11:16
Hi there @james016
Thank you as well to Aduxxi for their help so far, I just wanted to check in and see how things are looking since your install?
on 03-11-2023 11:58
Hi Adduxi
I am going to try tonight or at the weekend. We'll see how it goes
Thank you for your reply
James
on 03-11-2023 11:59
@ashleigh_c
I am going to install the hub either tonight or over the weekend and see how it goes
james
on 03-11-2023 17:29
Hi Adduxi
Setting the SIDs and passwords to match the Hub3 worked a treat. Only thing was that the coax on the splitter cable snapped when I removed it from the Hub3. Tech support did their thing here. Wall cable is now plugged into the router and will try to connect the 360 box via wifi. TV uses ethernet cable
James
on 03-11-2023 17:34
Would be better to get both boxes connected by cable if possible. Glad to hear you got it all working 👍
