Nowtv's avatar
Nowtv
Dialled in
3 months ago
Hub 3
hi, can someone tell me is the hub 3 fine with the M500?  Thanks.
  • The Hub 3 is widely used on speeds up to M500 & M600.
    Just be aware many domestic Wi-Fi devices are not capable of reaching 500+ Mbps.
    • legacy1's avatar
      But then the hub 3 wifi is outdated too.
        But anyone interested in "top of the range" Wifi, wouldn't be using the Hub's Wifi anyway ...  ;-)
    • Nowtv's avatar
      Nowtv
      Dialled in
      I have now upgraded to the M500, using my mesh 6 system, on my iPad Pro, this is my speed, which I am really pleased with.
    • Nowtv's avatar
      Nowtv
      Dialled in
      I now have the M500 this is my speed.
      • Anonymous's avatar
        Anonymous
        Approved
        And is that with the Hub 3?
        As mentioned at the start, the Hub 3 should be OK with speed unto around 600 Mb/s. WiFi, though, can be a bit if a black art, it's working for you on your iPad, then fine, no worries.
