Question about my installation in a flat with IRS system.
Davedoubledecks
Dear all,
im having my new virgin media installed next weekend in my flat with a IRS system. I’ve had a pre install visit and they took photos. The question I’m asking is on Monday I have Virgin turning up to replace my faceplate which I assume is the one with my satellite and tv aerial connections but recent I had this fixed by a company called SCCI Alphatrack and I asked the engineer about getting Virgin media and he told me that they replace the faceplate and connect to virgin via the connection box outside wall. He also says that Virgin ask them to do this and then they charge Virgin. He had the faceplate in the van but couldn’t install it as the current job was not with Virgin. So will the visit on Monday be done as Virgin are coming out not SCCI. I’ve told customer services about this but not sure they understood.
Thanks and hope this makes sense.
David
17 REPLIES 17
IRS faceplates have been installed for years in flats to provide multiple outlets for DTT, satellite and radio. When VM provides its service you have "VM over IRS" whereby the faceplate is replaced by a VM one which adds the outlet for the coaxial cable. (I'm careful not to say "VM's coaxial cable" as the existing cable in the building is used to carry VM's signals.) VM is responsible for the work and some of it is often contracted out to a specialist like SCCI.
Hub 5, TP-Link TL-SG108S 8-port gigabit switch, 360
My Broadband Ping - Roger's VM hub 5 broadband connection
Yes exactly but it was trying to arrange to get faceplate changed with cable connected to VM on the junction box on the apartment block wall and customer services not fully understanding this and even the engineer who did the pre install survey had not seen this setup before. Keep my fingers crossed by a week on Thursday midday I’m connected.
Roger_Gooner
Can you please come back here and report on what SCCI did.
 Well I’ve got the first part of my installation completed on th virgin over IRS system so just the virgin engineer to come in the morning after it was it was moved from this afternoon to get connected.
so the first picture is the virgin box where the cable comes from the street and then the engineer runs a coaxial cable to the next box and now uses one of the cables going to my flat for tv say etc for virgin media.
Roger_Gooner
The first is the primary lockbox. How many flats in the building?
8 flats total and only 1 flat using virgin media currently
Davedoubledecks
All installed with a HUB 5 and all working great. Well happy.
Hi Davedoubledecks,
Thanks for taking the time to contact us via the Community. It's lovely having you on board with us in the Forums. 🙂
We're happy to hear you've been installed and the services are going well.
We're sure things will continue but if any issues do crop up, pop back to us in the Community and we can help 🙂
Kath_F
