Monsoon17's avatar
Monsoon17
Outdoor cable cut
Hello. I accidently cut the cable in the garden yesterday. It's a twin cable, with the smaller wire completely cut through and the larger wire partly cut through. Broadband still works fine, and I think the smaller wire is the old telephone line no longer in use. If I just wrap it in duct tape any idea if that would suffice? Or should I get it properly fixed? Thanks.
  • I'd suggest getting it fixed as you could introduce noise into your and neighbours lines.
    It shouldn't cost anything since the line wasn't correctly buried.
  • Hi Monsoon17,
    Thank you for your post and welcome to the community.
    Thank you for letting us know about the cable. We can certainly have this looked into.
    I will private message you now to confirm your details.
    ^Martin
  • All fixed. An engineer came out and fitted a new cable. Impressed with Virgin's service on this occasion.
