- Client62Alessandro Volta
Are the neighbours reporting to the service speed at the VM Hub or the Wi-Fi capabilities of their laptop ?
The link below shows the speed to the VM Hub as well as how fast the devices works with the Hub:
Got a friendly neighbours ? Ask for a demo it only takes a short time to complete.
A 1Gb service should be about 1130Mb/s at the Hub 4 or Hub 5. - carl_pearceSuperstar
Exactly!
The amount of users that expect full speed to one device when it's not even capable of it (Wi-Fi 5, for example).
Even most wired devices on 1Gbps ethernet ports will be limited to 900-940Mbps.
You share the full bandwidth across several devices at the same time.
Related Content
- 2 years ago
- 2 months ago
