- jbrennandVery Insightful Person
What Hub model is it - Hub3 I presume ?
A VM person will respond on here soon
- Gareth_LForum Team (Retired)
Hello Griff7772.
Thanks for your first post and welcome to our community.
Sorry to hear you are having an issue with the red light on your hub
I'd like to investigate this for you as we will need to send an engineer out and swap this over for you.Would you be able to make sure the Hub is away from any direct sources of heat and well ventilated.
If you can check your logo at the top right of your screen that would be great.
Gareth_L
- Griff7772Joining in
Hi Gareth,
finally problem solved, managed to speak to a very helpful Frenchman and a new hub should be sent to me in the next few days😁
hurrah
Related Content
- 4 months ago
- 1 year ago
- 2 years ago
- 1 year ago
