- unisoftSuper solver
If VM ty to charge and its quite a bit, you can get brand new "Virgin Media Wallbox" from ebay and fit yourself.
As the wiring is connected and can see you have an inline isolator then its simply two screws probably into existing wall plugs. Telephone cable isn't required if your aaddress has gone digital (phone in back of hub instead of socket).
- AdduxiVery Insightful Person
Most likely it will be a £25 non fault call-out fee for this work.
- Matthew_ML
Hey jmercer13, thank you for reaching out and a warm welcome to the community I am sorry to hear this.
As mentioned there would be a one off £25 for this.
I will send you a DM so can get the ball rolling on this.
Related Content
- 1 year ago
- 7 months ago
- 1 year ago
- 7 months ago
- 1 year ago
