snossis69's avatar
snossis69
4 years ago
hub 5 - keeps disconnecting
set my new hub 5 up last week but keeps disconnecting from the internet is this normal for a new hub
  • Jodi_S's avatar
    Jodi_S
    4 years ago
    Hi snossis69,
    A warm welcome and thanks for posting. Sorry to hear that you're currently experiencing regular dropouts with your internet services on both a wired and wireless connection.
    Remotely looking from our end, we have located your account and run some diagnostic checks. We have found that your downstream power levels are out of specification, and this would require and engineer to resolve this issue for you.
    Please let me know if you would be happy for us to arrange this.
    Kind regards Jodi.
  • Anonymous's avatar
    Anonymous
    In Review
    Depends. Is it losing full connectivity or is it just Wifi devices dropping off?
    • snossis69's avatar
      snossis69
      • my devices stay connected to the hub but it just loses all internet for a minute then reconnects this happens 4 or 5 times a day
        Anonymous
        In Review
        And wired devices as well?
  • I'm having the same issue since I upgraded last week. Several times a day the hub just disconnects for a couple of minutes flashing red then gets back online.
    I've been told this is due to an issue in my area but the service status checker states that there are no issues.
    Any ideas?
    • Arissa_H's avatar
      Arissa_H
      Hi John_Clay,
      Welcome and thank you for posting on our forums.
      Sorry to see you are having issues with our broadband; we have checked from our systems and we can see some of your power levels are out of spec. This means you will need an engineer to resolve this issue.
      We will send you a private message to get this arranged. Watch out for the purple envelope.
      Thank you.  😊
    • Arissa_H's avatar
      Arissa_H
      Thank you for replying on the private message. 😊
      I have booked an engineer appointment, to access this you can click this link https://virg.in/manageorders. This way you can change the date to the day that suites you best.
      Let us know if there is anything we can help with.
      Thank you.
      • mtapsall's avatar
        mtapsall
        Hi there
        I upgraded to the hub 5 yesterday and since I also loose connection for a minute or so and then everything comes back up.
        anything I can do?
        thanks
  • Hi,
    I have recently moved to hub 5 but I am facing the same issue. I tried using the router in modem only mode as well but it keeps on disconnecting many times in the day which causes even my personal router which I have connected through lan to go down. It happens mostly when I am on zoom meetings which is really frustrating as I am not able to get my work done.
    Regards,
    Anshu Maheshwari
  • Keep having the same issue since Hub 5!
    I already had an engineer come in and change the Hub 5 to another and still same issue.
    Really can't wait to leave VM for another ISP because this is getting to my nerves
    No power levels are not the issues, SnR is not the issue, cable, and everything were looked at when the engineer came on Monday the 16/01/2023
    I keep getting disconnected, I even showed the Hub 5 logs and clearly the person did not understood them
    Can I please get some competent people? Really I have been trying to get hold on someone who actually understands the issues but none of team in whatever call centre you're outsourcing is helping.
    I have been having this issue for months now.
    • John_GS's avatar
      John_GS
      Hi Faruque051
      I am sorry to hear you're having issues with the disconnections. I have not been able to locate your system from the Forum details provided.
      Can you post your Hub status and logs? How to do this;
      • Copy/paste the data from each of the tabs as text into a 'REPLY' as opposed to 'QUICK REPLY'. Please do not include your MAC address.
      Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc - You can do this at https://www.thinkbroadband.com/broadband/monitoring/quality
      Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum 🙂
      Is this also affecting both wired and wireless? Or just wireless?
      If just wireless devices, please try the Connect App - https://www.virginmedia.com/broadband/connect-app - when downloaded, you'll be able to do a wireless scan in the property which will identify any coverage blackspots. It'll optimise them where possible and also if a Pod is needed, you'll be prompted to order.
      Best wishes,
      • anshu83's avatar
        anshu83
        Attached above is a screenshot of my network logs. As mentioned earlier, when this issue happens both wireless and lan go down
  • Carley_S's avatar
    Carley_S
    Thanks so much for your private message anshu83
    I have now booked you a visit for your hub disconnection issue – you can check the date and time via your online account here. If you have any issues with accessing your online account or unable to see your visit, please do let us know and we’ll pop you a message to confirm.
    There will be no charge for this visit unless:
    •    The technician diagnoses the faults as not being caused by our network/equipment
    •    The technician discovers that the fault or problem relates to your equipment
    •    The technician discovers that the fault or problem relates to any system that we are not responsible for
    The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
    Please ensure there is someone over the age of 18 present at the time of the visit. If you need to change or cancel your appointment you can do this online or via the MyVM app by 4pm the day before the appointment.
    If you do miss an agreed appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment.
  • I'm having the exact same issues. My hub 5, 1Gbps keeps losing internet connection multiple times a day. devices stay connected to the WIFI but I have no internet connection at all for a few minutes until it reconnects, The exacts same issue for the PC when plugged into an ethernet. This has been going on for a few months now and I have tried all the recommended troubleshoot options with nothing solving this issue.
    • martinwood333's avatar
      martinwood333
      In the end after a couple engineer visits where they checked the drop cable and junction boxes (and even re-terminated the lines), the Hub 5 was the fault. We were switched to the Hub 4 and we've been problem-free since. The Hub 4 fixed the issue immediately.
      I can only guess there must be some incompatibilities with the Hub 5 and some of the infrastructure.
    • Kath_P's avatar
      Kath_P
      Hi darksinfulldeed,
      Thanks for taking the time to post about your issues in the Community.
      We're sorry to hear you;re having an issue with disconnections multiple times a day. Taking a look at things this end, I can see the downstream and upstream power levels are looking good however your overall signal levels are a little low. As well as this, I can see the disconnections are logging too and there have been quite a high number within the last week.
      We won't be able to fix this remotely so I would like to arrange for an engineer to come to take a look at this for you. I just need to confirm the address to ensure we are booking the visit on the correct account. I have sent you a direct message to allow us to do this with you in a private space. Just click on the little ✉ at the top right-hand side of the page to access your inbox. 😊
    • Kath_P's avatar
      Kath_P
      Hi darksinfulldeed,
      Thanks for coming back to via private message to confirm your information. 🤩
      I have booked you in for the next available appointment. To view this please sign in to My Virgin Media here 👉 My VM. Once you log in scroll down to Orders & appointments then click on View your orders. Please note it can take up to 24 hours to show but you should also receive a text message with the details. You can also view this in the My VM app. If you have any issues with accessing your account or unable to see your visit, please do let us know and we’ll pop you a message to pass data protection and confirm the appointment details.
      Just to confirm, there will be no charge for this visit unless:
      • ➡ The technician diagnoses the faults as not being caused by our network/equipment
      • ➡ The technician discovers that the fault or problem relates to your equipment
      • ➡ The technician discovers that the fault or problem relates to any system that we are not responsible for
      • ➡ The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
      Please ensure there is someone over the age of 18 present at the time of the visit. If you need to change or cancel your appointment you can do this online or via the MyVM app by 4pm the day before the appointment. If you do miss an agreed appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment.
      We will continue to monitor your services and if we can see that the fault has cleared and the visit is no longer required we will cancel the appointment and let you know by text and email.
      Let us know how the appointment goes. 😊
      Take care.
      • darksinfulldeed's avatar
        darksinfulldeed
        Hey we are still having the same issues. Nothing has improved our internet is still cutting out multiple times a day and we are getting extremally frustrated with this now. Please can we get this fixed soon as we have had nothing but problems with the HUB 5.
  • Good evening
    I am having similar problems to the rest of the posters and suspect the Hub 5 may be the issue.
    Intermittent drops throughout the day since upgrading to Gig1 and the Hub 5. Engineer visit a couple of months ago, replaced with a new Hub 5. Problem seemed okay for a little while but I'm now getting 7-8 drops a day. I have to pull the cable on the back of the Hub 5 to get it to come back on. Both ethernet and WiFi devices disconnect.
    At the time the engineer advised me to disconnect my Google WiFi router and use the Hub 5 in router made. I was initially stubborn and refused as it has worked fine for years. I suspect the issue is VM's equipment. Nevertheless I have now tried what he said and the problem remains now that the Hub 5 is in router mode.
    I rang customer services last week and they advised me to do a pinhole reset and said they'd monitor the connection for 24 hours. I did so.
    Just rang again tonight. They advised me to do another pinhole reset and said they'll monitor it again for 24 hours. I have done so, but this is not going to fix the problem - as I have tried it many times.
    Any help greatly appreciated.
    Thanks 🙂
    • Travis_M's avatar
      Travis_M
      Hi matttye88
      Thanks for posting on our community forum and sorry to hear about the issue with your broadband.
      I am going to drop you a private message now to collect some more information and investigate further, keep an eye on your inbox for a message from myself.
    • ns006m's avatar
      ns006m
      The way I cured my disconnect problems was to log into the router and put it into modem mode. So far no more disconnects. This means that you will have to use RJ45 cables of the appropriate specs to connect to the hub.
      Also make sure you network card is at the same speed as your internet connection, i.e. a 1gig internet speed needs a 1 gig network card.
