a month ago
To supplement a previous thread, I have now obtained a Hub 5.0 after switching to Gig1 package.
Still getting some uncorrected errors on download and some T3 timeouts on upload (this is after around 4 days or so of uptime - so someone more knowledgeable can tell me if these are within normal values).
In addition, I recently also acquired a wifi pod (black) to bring coverage to some areas of the house that had no signal at all, i.e. the upstairs room furthest from the hub.
Now while that has improved the signal, it is pretty much forcing all other devices that are upstairs (the majority of the time) onto 2.4GHz and therefore limiting speed to around 50mbps, when these were perfectly fine on 5Ghz before, with RSSI's of -70dB or thereabouts, achieving routinely around 600 mbps.
The wifi coverage is no good if the band steering slows everything else down to 2.4ghz just selecting by signal strength alone. From what I read there is not much I can do about this but thought someone may have some tips?
Thanks - see stats below...
3.1 Downstream channels
159 | 94 | 4K | 1840 | QAM 4096 | 1108 |
159 | Locked | 43 | 1.6 | 2866547840 | 307 |
3.1 Upstream channels
14 | 10 | 39.2 | 2K | QAM 256 |
14 | OFDMA | 200 | 74000000 | 3 | 0 |
a month ago
Post up the full data set as per this...
______________________________
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
a month ago
Hi I initially didn't post these as thought it was just the DOCSIS 3.1 stats required. See below as requested...
3.0 Downstream channels
1 | 139000000 | 0.7 | 41 | QAM 256 | 1 |
2 | 147000000 | 0.8 | 41 | QAM 256 | 2 |
3 | 155000000 | 0.9 | 41 | QAM 256 | 3 |
4 | 163000000 | 0.9 | 41 | QAM 256 | 4 |
5 | 171000000 | 0.9 | 41 | QAM 256 | 5 |
6 | 179000000 | 0.8 | 41 | QAM 256 | 6 |
7 | 187000000 | 0.6 | 41 | QAM 256 | 7 |
8 | 195000000 | 0.4 | 41 | QAM 256 | 8 |
9 | 203000000 | 0.4 | 41 | QAM 256 | 9 |
10 | 211000000 | 0.4 | 41 | QAM 256 | 10 |
11 | 219000000 | 0.4 | 41 | QAM 256 | 11 |
12 | 227000000 | 0.6 | 41 | QAM 256 | 12 |
13 | 235000000 | 0.7 | 41 | QAM 256 | 13 |
14 | 243000000 | 0.8 | 41 | QAM 256 | 14 |
15 | 251000000 | 0.9 | 41 | QAM 256 | 15 |
16 | 259000000 | 0.9 | 41 | QAM 256 | 16 |
17 | 267000000 | 0.7 | 41 | QAM 256 | 17 |
18 | 275000000 | 0.7 | 41 | QAM 256 | 18 |
19 | 283000000 | 0.6 | 41 | QAM 256 | 19 |
20 | 291000000 | 0.4 | 42 | QAM 256 | 20 |
21 | 299000000 | 0.4 | 42 | QAM 256 | 21 |
22 | 307000000 | 0.4 | 41 | QAM 256 | 22 |
23 | 315000000 | 0.5 | 41 | QAM 256 | 23 |
24 | 323000000 | 0.6 | 41 | QAM 256 | 24 |
25 | 331000000 | 0.8 | 41 | QAM 256 | 25 |
26 | 339000000 | 0.7 | 41 | QAM 256 | 26 |
27 | 347000000 | 0.6 | 41 | QAM 256 | 27 |
28 | 355000000 | 0.5 | 41 | QAM 256 | 28 |
29 | 363000000 | 0.2 | 41 | QAM 256 | 29 |
30 | 387000000 | 0.1 | 41 | QAM 256 | 32 |
31 | 395000000 | 0 | 41 | QAM 256 | 33 |
32 | 419000000 | 0.2 | 41 | QAM 256 | 36 |
1 | Locked | 41 | 14 | 0 |
2 | Locked | 41 | 9 | 0 |
3 | Locked | 41 | 5 | 0 |
4 | Locked | 41 | 10 | 0 |
5 | Locked | 41 | 10 | 0 |
6 | Locked | 41 | 3 | 0 |
7 | Locked | 41 | 6 | 0 |
8 | Locked | 41 | 3 | 0 |
9 | Locked | 41 | 5 | 0 |
10 | Locked | 41 | 10 | 0 |
11 | Locked | 41 | 2 | 0 |
12 | Locked | 41 | 4 | 0 |
13 | Locked | 41 | 9 | 0 |
14 | Locked | 41 | 10 | 0 |
15 | Locked | 41 | 11 | 0 |
16 | Locked | 41 | 15 | 0 |
17 | Locked | 41 | 10 | 0 |
18 | Locked | 41 | 11 | 0 |
19 | Locked | 41 | 9 | 0 |
20 | Locked | 42 | 6 | 0 |
21 | Locked | 42 | 16 | 0 |
22 | Locked | 41 | 8 | 0 |
23 | Locked | 41 | 21 | 0 |
24 | Locked | 41 | 18 | 0 |
25 | Locked | 41 | 16 | 0 |
26 | Locked | 41 | 29 | 0 |
27 | Locked | 41 | 26 | 0 |
28 | Locked | 41 | 13 | 0 |
29 | Locked | 41 | 14 | 0 |
30 | Locked | 41 | 16 | 0 |
31 | Locked | 41 | 17 | 0 |
32 | Locked | 41 | 24 | 0 |
159 | Locked | 43 | 1.6 | 2892609163 | 377 |
a month ago
3.0 Upstream channels
0 | 49600000 | 45 | 5120 | QAM 64 | 9 |
1 | 43100000 | 45 | 5120 | QAM 64 | 10 |
2 | 36600000 | 45 | 5120 | QAM 64 | 11 |
3 | 30100000 | 45 | 5120 | QAM 64 | 12 |
4 | 23600000 | 45.3 | 5120 | QAM 64 | 13 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 3 | 0 |
02-04-2024 16:45:07 | notice | GUI Login Status - Login Success from LAN interface |
30-03-2024 18:15:25 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
30-03-2024 18:15:25 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
30-03-2024 18:15:23 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
30-03-2024 18:15:23 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
30-03-2024 07:29:19 | error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-03-2024 03:29:49 | notice | GUI Login Status - Login Success from LAN interface |
26-03-2024 20:37:51 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-03-2024 20:37:51 | notice | US profile assignment change. US Chan ID: 14; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-03-2024 20:37:47 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
26-03-2024 20:37:41 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-03-2024 20:37:41 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
a month ago
All stats look fine.
See if anything in message 5 in this thread helps to connect Pods…
https://community.virginmedia.com/t5/Networking-and-WiFi/WiFi-boosters-needed/m-p/5122436#M497217
