AMCX's avatar
AMCX
Wifi Dropping
I’ve seen a similar issue reported but not resolved. Hub 5 has been refreshed and rebooted phones switched off and back on all the easy stuff but the wifi keeps dropping. Worked well for years just started happening 2 days ago Virgin apps say everything is working well and no service issues. Any offers?
  • Gareth_L's avatar
    Gareth_L
    Hello AMCX.
    Thanks for bringing the WiFi issue to our attention. Sorry as well for any inconvenience this is causing you. I can imagine it is extremely frustrating for you.
    What I would like to do is look into this in a bit more depth and help get the connection fault fixed.
    If you can check the logo top right of your screen that would be great.
    Gareth_L
    • AMCX's avatar
      AMCX
      Thanks Gareth. I thought I’d been blanked but saw the replies went into my spam folder.
      After copious reboots and return to factory settings, I finally got a steady signal back. I’ll be back in touch if it happens again.
      • Alex_RM's avatar
        Alex_RM
        Great to hear AMCX 😊
        Thanks for letting us know.
        Alex_Rm
    Settings to discourage mobiles from dropping Wi-Fi and reverting to the GSM mobile data.
    For iPhones...
    Disable "Wi-Fi Assist"    Ref:https://support.apple.com/en-us/102228
    For Android phones...
    Disable "Switch to mobile data"
    Settings >> Connections >> Wi-Fi >> ... ( 3 dot menu ) >> "Switch to mobile data"  ( set to OFF )
