Wifi Calling Not Working For Vodafone Mobile
JBcegb
Hi Virgin Media tech support.
My Virgin broadband is not allowing Vodafone mobiles to use Wi-Fi calling. When I use my Vodafone mobile in other locations with a different broadband carrier Wi-Fi calling works fine.
Other carriers mobiles - eg EE can use WiFi calling  on my Virgin broadband .
So I have narrowed the cause of the problem to Virgin Media broadband setup at my home address.
How do I request Virgin Media to investigate and correct this problem ?
6 REPLIES 6
Zach_R
Hi @JBcegb
I'm so sorry to hear that you're having some issues with Wi-Fi Calling. Have you tried inserting the Vodafone SIM card into a different device? That way we can narrow down if the issue lies with the mobile device or not.
Zach - Forum Team
New around here? To find out more about the Community Forums, take a look at our FAQs!
hi Zach_R - the handset and Voda sim are able to use wi-fi calling at other locations where the wi-fi is delivered via a different broadband carrier to Vodafone.
From other chats on this subject it would appear the Virgin Media broadband service has to have a particular setting enabled to support Vodafone mobile Wi-Fi calling .
Please advise what details are needed for Virgin Media to investigate this fault & the setup of their broadband service at my home location.
Disable "Child Safe" in the VM online account, or set the mobile to use a Public DNS.
Thank you for the suggestions Client62. I’ll come back to you when I’ve tried these. 👍
Hi Zach_R, re my last message - I mistakenly said Vodafone in the first paragraph -  it should read
the handset and Voda sim are able to use wi-fi calling at other locations where the wi-fi is delivered via a different broadband carrier to Virgin Media.
unisoft
Knows their stuff
If there is an option in your hub for "IpSec Passthru", then enable it as all WiFi Calling uses an IPSec tunnel that must bypass NAT to work. I use my own router, and had to do this and I know some of the VM hubs had this option but can't remember which ones.
