andrew1965golf's avatar
andrew1965golf
3 years ago
WiFi pod won’t connect after Hub 5 self install.
Hi, installed a new hub 5 yesterday, but can’t get my WiFi pod from hub 3 to connect. Help?
  • Hi andrew1965golf,
    We're sorry to hear your WiFi pod isn't working with your new hub. We will need to reconfigure this to get it working again but in order to do that I will need to confirm some information with you to pass security.
    I have sent you a direct message to allow us to do this with you in a private space. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
  • Thanks for sticking with me via private message andrew1965golf 🙂🙂
    I have re-provisioned the pod to work with your Hub 5 now. If you can just reboot your hub, and pod, this should allow them to connect although it can take up to 10 minutes.
    Let us know how things go for you.
    Many thanks,
    • andrew1965golf's avatar
      andrew1965golf
      Hi, the pod light has gone out and is now showing on the connect app with devices connected. Thank you so much
      Andrew
      • Paul_DN's avatar
        Paul_DN
        Hi Andrew,
        Glad to hear your pod is now connected and showing on your Connect App, if you have any further issues, please do not hesitate to reach back out.
        Paul.
