Jpt44's avatar
Jpt44
WiFi dropouts every few minutes/hours and router resets every few hours.
For MONTHS/YEARS, my virgin media router has been restarting itself every few hours, causing for the WiFi to be down for atleast 3-4 minutes at a time. This has been happening for SOO long that I cannot even remember when it started. When looking at the network logs, there are many 'warning' codes and then the router decides to restart.
Another issue that has quite recently arose within the past week or so, the WiFi will disconnect my computer, then reconnect me a few seconds later. This has been happening every few minutes for the past few days and makes using the connection unbearable. Also, the router is capping my computer to 80mbps and after changing the MAC address of my computer (so that it detects it as a different device), it will uncap and let me receive the normal 300-500 mbps.
Overall, there are just many issues which have been happening and I really do need a resolution to these problems as there are just WAY too many.
The post linked here, seems to have also had the same issue and it has been resolved.
I will put the logs below here. The only thing that I can tell from these is that when it says 'REGISTRATION COMPLETE - Waiting for Operational status', these are the times that the router has reset itself. If anything else is needed, please let me know.
Network Logs:
17-11-2024 11:33:52warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-11-2024 11:33:52noticeUS profile assignment change. US Chan ID: 14; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-11-2024 11:33:48noticeREGISTRATION COMPLETE - Waiting for Operational status
17-11-2024 11:33:42warningDynamic Range Window violation
17-11-2024 11:33:42warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-11-2024 11:33:42warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-11-2024 11:33:42warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-11-2024 11:33:36noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-11-2024 11:33:36noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-11-2024 11:33:29warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-11-2024 11:33:27noticeHonoring MDD; IP provisioning mode = IPv4
17-11-2024 11:33:08criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-11-2024 11:33:02criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-11-2024 11:33:01criticalCable Modem Reboot because of - HW or Power-On Reset
17-11-2024 00:52:51criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-11-2024 00:52:07criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
17-11-2024 00:52:02criticalCable Modem Reboot because of - tr069-reboot
17-11-2024 00:52:02criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
16-11-2024 23:17:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
16-11-2024 23:17:06criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
16-11-2024 23:17:05criticalCable Modem Reboot because of - tr069-reboot
16-11-2024 13:37:18criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
16-11-2024 13:37:17criticalCable Modem Reboot because of - HW or Power-On Reset
15-11-2024 19:46:07criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
15-11-2024 19:46:00criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
15-11-2024 19:45:59criticalCable Modem Reboot because of - HW or Power-On Reset
15-11-2024 12:05:21criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Upstream:
04960000043.35120QAM 649
143100000435120QAM 6410
23660000043.35120QAM 6411
330100000435120QAM 6412
42360000043.35120QAM 6413
0ATDMA0000
3ATDMA0040
4ATDMA0000
141037.02KQAM 256
14OFDMA2007400000000
Downstream:
13310000004.542QAM 25625
21710000004.542QAM 2565
31790000004.441QAM 2566
41870000004.341QAM 2567
51950000004.641QAM 2568
62030000004.842QAM 2569
7211000000542QAM 25610
82190000004.942QAM 25611
92270000004.642QAM 25612
102350000004.642QAM 25613
112430000004.642QAM 25614
122510000004.441QAM 25615
132590000004.241QAM 25616
142670000004.341QAM 25617
152750000004.542QAM 25618
162830000004.541QAM 25619
172910000004.541QAM 25620
182990000004.341QAM 25621
193070000004.441QAM 25622
203150000004.642QAM 25623
213230000004.642QAM 25624
223390000004.642QAM 25626
233470000004.742QAM 25627
243550000004.742QAM 25628
253630000004.741QAM 25629
263710000004.741QAM 25630
273790000004.841QAM 25631
283870000004.742QAM 25632
293950000004.541QAM 25633
304030000004.541QAM 25634
314110000004.541QAM 25635
324190000004.541QAM 25636
1 4200
2 4200
3 4100
4 4100
5 4100
6 4200
7 4200
8 4200
9 4200
10 4200
11 4200
12 4100
13 4100
14 4100
15 4200
16 4100
17 4100
18 4100
19 4100
20 4200
21 4200
22 4200
23 4200
24 4200
25 4100
26 4100
27 4100
28 4200
29 4100
30 4100
31 4100
32 4100
159944K1840QAM 40961108
159 411.41326866650
1 Reply
  • Ilyas_Y's avatar
    Ilyas_Y
    Hey Jpt44 Thanks for reaching out to us and a warm welcome to the Virgin Media Community forums. 👋🏽
    I'm sorry to hear about the issues with the broadband you're facing.
    I will look in to this for you and investigate the matter for you.
    I will send a private message.
    Kind regards,
    Ilyas.
